strong fuel smell in engine oil
Old Apr 11, 2004 | 08:58 PM
eswaroop's Avatar
Default strong fuel smell in engine oil
Hi,
My engine oil smells strongly of fuel. Any ideas what might be the problem? Is this normal?
I have been having problems with my car's power and performance lately right after a valve adjustment in which the valves were adjusted too tight.. The fuel smell in the oil is one thing that caught my attention, just wondering if there is a connection..
Thanks
Es
99 Honda accord ex 4cyl
Old Apr 11, 2004 | 11:27 PM
Two_K Si's Avatar
Default Re: strong fuel smell in engine oil (eswaroop)
Do you do alot of short trips? Running rich? Taking a nice long drive on the highway will burnoff all water and fuel from the oil.
Old Apr 12, 2004 | 07:04 AM
eswaroop2's Avatar
Default Re: strong fuel smell in engine oil (Two_K Si)
It seems to be running rich after a valve adjustment I had gotten done on the car a couple of weeks ago..
Old Apr 12, 2004 | 07:51 AM
MrBui's Avatar
Default Re: strong fuel smell in engine oil (eswaroop2)
could be bad map sensor....better check that oil...had a guy here collect about a quart of gas inside his motor....gas+heat= no good
Old Apr 12, 2004 | 09:16 AM
spender1326's Avatar
Default Re: strong fuel smell in engine oil (n20need4vtec)
I'm having kind of the same problem. What's the map sensor? O2 Sensor? Fuel Map? Please explain
Thx
Old Apr 12, 2004 | 10:08 AM
eswaroop's Avatar
Can the MAP sensor go bad because of a valve adjustment?? I am suspicious that the valves are leaking, but can the map sensor go bad because of bad intake valves??
skylerreniger
Dec 1, 2012 07:04 PM
stangbanger2112
Jan 1, 2012 08:15 PM
tech23
10
Feb 11, 2010 07:40 AM
J-Man05
Oct 13, 2007 02:01 PM
