help ! I got no VTEC...
Old Apr 12, 2004 | 07:39 PM
Gonzo_SiR's Avatar
Default help ! I got no VTEC...
ok before you guys bash me for not doing a search... I did do one...
here's what I have: 1989 CRX B16A w/Type R pistons
Cel code 22 (VTEC pressure switch)
what I've done....
a) put in 4.5 quarts of oil
b) ohmed out entire VTEC wire 0 ohms (wire harness to solenoid input)
c) provided it with 12v from wiring harness, good healthy click from solenoid
d) swapped with buddies ECU, PR3 mine is a PWO, same code, no VTEC
e) unhooked solenoid connector at idle, no bogging or anything
f) car was warm, nice and sunny out
anything else I can do...? please help....
Old Apr 12, 2004 | 07:48 PM
BuddhaSiR's Avatar
Default Re: help ! I got no VTEC... (Gonzo_SiR)
check the vtec pressure switch and circuit
Old Apr 12, 2004 | 07:49 PM
d00kee's Avatar
hmm that is very wierd, ill do a search and see if i come up with anything for ya.
Old Apr 12, 2004 | 07:53 PM
Gonzo_SiR's Avatar
Default Re: help ! I got no VTEC... (d00kee)
where exactly is the VTEC pressure switch and what does it look like...?
Old Apr 12, 2004 | 08:28 PM
mmuller's Avatar
Mad Scientist
the vtec pressure switch is on the vtec solenoid assembly.
check the sensor and check oil pressure
f2m0u5
11
Mar 26, 2006 11:43 PM
JDM-MONKEY
Jan 14, 2006 10:10 AM
sharkcohen
Mar 11, 2005 07:55 AM
InfamousRS
May 21, 2002 04:09 PM
