B16a in 89Si and having an ECU 22??? Vtec :(
Old Apr 11, 2004 | 05:54 PM
shaddr3's Avatar
Default B16a in 89Si and having an ECU 22??? Vtec :(
Ok I noticed my ECU tonight, says ECU Code 22 on my B16a new ECU.
Code 22 is Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch). I havent learned enough about motors and all the techinical stuff yet, but how do I go about fixing whatever the problem is? I look under the hood, and on the left side of the block, theres a plug undone, and its not seeming to go back in. Could anyone tell me why my ecu is throwing this code?
Old Apr 11, 2004 | 06:47 PM
RedlinedVTEC's Avatar
Default Re: B16a in 89Si and having an ECU 22??? Vtec :( (shaddr3)
Is the dangling connector coming from the VTEC solenoid? Did you wire VTEC?
Old Apr 11, 2004 | 07:29 PM
shaddr3's Avatar
Default Re: B16a in 89Si and having an ECU 22??? Vtec :( (RedlinedVTEC)
I did not do the swap, and most likely dont have the knowledge to do so. I am looking at the 91 CRX service manual online and I cant find the Vtec stuff ANYWHERE. Here are some pictures of the motor. On the left hand bottom corner, theres a bunch of wires not hooked up, wondering what they are...
View them here http://community.webshots.com/...rbPPk . :-/ I really need some help on learning stuff. Im picking it up, very slowly though, I forget things all the time.
Old Apr 11, 2004 | 07:56 PM
The reason you can't find any VTEC stuff in the service manual was that US spec EFs did not come with any VTEC motors. Here's a helpful diagram by Katman:
I don't know who did your swap or how your wiring is (as I could not get your pics to work), but if you don't feel comfortable fixing this yourself then I recommend you take the car to a reputable shop to get things fixed for you or maybe find a competent h-t member here that is local to you to lend you a hand. Good luck.
Old Apr 11, 2004 | 10:30 PM
d00kee's Avatar
thats a good pic. but yeah that should help him. but where did u get that pic at?
Old Apr 12, 2004 | 07:00 AM
Default Re: B16a in 89Si and having an ECU 22??? Vtec :( (d00kee)
From Katman's/ff-squad website: http://ff-squad.com/tech.
Old Apr 12, 2004 | 12:33 PM
d00kee's Avatar
thanks
Jdmb16a_integra
Jan 2, 2012 09:21 PM
Beasting EF22
22
Aug 23, 2011 02:33 PM
RB_EJ8
Aug 6, 2008 03:56 PM
inline4
Jul 27, 2006 03:05 AM
311
Oct 8, 2002 11:42 AM
