wiring obd2 distributor to obd2b harness? is it possible?
Old Apr 9, 2004 | 11:26 PM
heel_touge's Avatar
Default wiring obd2 distributor to obd2b harness? is it possible?
i just found a wiring diagram for the two.
the 96' obd2 has 9 wires
the 00' obd2b has 8.
i figured out the 9th wire is the engine speed output wire.
will the obd2 distributor run correctly if it is wired up to the obd2b harness WITHOUT the blue engine speed output wire?
thanx in advance.
Old Apr 10, 2004 | 11:36 AM
heel_touge's Avatar
Default Re: wiring obd2 distributor to obd2b harness? is it possible? (1slowcivic)
bump.
i honestly think i am invisable.
Old Apr 1, 2006 | 09:57 PM
Ch3mik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowcivic &raquo;</TD></TR><TR><TD CLASS="quote">bump.
i honestly think i am invisable.</TD></TR></TABLE>
hahhhaaah
Old Apr 3, 2006 | 10:01 AM
Ch3mik's Avatar
Default Re: wiring obd2 distributor to obd2b harness? is it possible? (Ch3mik)
i hat epeople on here that are of no help
Old Apr 4, 2006 | 12:29 AM
Ch3mik's Avatar
bumpo again
Old Apr 4, 2006 | 11:18 AM
Ch3mik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowcivic &raquo;</TD></TR><TR><TD CLASS="quote"> wiring obd2 distributor to obd2b harness? is it possible?
thanx in advance. </TD></TR></TABLE>
prob wont. just run it from the dist to the drvr side. its the blu wire chillin by itself
Old Apr 4, 2006 | 01:34 PM
Relic1's Avatar
it will run without the tach wire, but your tach will not work.
OBD2b gets it's tach signal from the ECU.
run the blue wire like Ch3mik said and everything will work.
Old Apr 5, 2006 | 08:39 AM
Ch3mik's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">it will run without the tach wire, but your tach will not work.
run the blue wire like Ch3mik said and everything will work.</TD></TR></TABLE>
Old Apr 6, 2006 | 09:33 AM
Relic1's Avatar
thanks to EE_Chris for putting my head back on my shoulders with this....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">it will run without the tach wire, but your tach will not work.
I am wrong.
With the OBD2b ECU the blue wire is not needed from the distributor to the driver's shock tower at all.
However if you're running a OBD1 or OBD2a conversion then you need the blue wire.
Old Apr 6, 2006 | 10:07 PM
Ch3mik's Avatar
thats wat i had said
Old Apr 7, 2006 | 07:49 AM
Relic1's Avatar
Default Re: (Ch3mik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">thats wat i had said </TD></TR></TABLE>
I think I need beltone or glasses or something.
civic00_dude
Sep 15, 2008 07:43 AM
ToeJam
May 29, 2007 10:33 PM
Neukin
Feb 22, 2003 10:39 AM
ef civic
Sep 17, 2002 05:37 PM
