O2 Sensor Problem (LONG)
Old Apr 8, 2004 | 11:00 AM
mraudio13's Avatar
Default O2 Sensor Problem (LONG)
ok here is the deal, I have a 01 GSR and I keep throwing a Voltage too High in bank 1 O2 sensor. This is the 3rd o2 sensor in 2 Months. I had a JRSC on my car for 2 weeks and the Fuel pressure was going well over 100psi when WOT. I took the JRSC off my car for fear of Blowing up my car. Put a Skunk2 intake mani with hondata gasket and since i have done that, i can't stop this code from poping up. The weird thing is that when I reset the code the car is fine for about 1 day then the code comes back up. The car runs fine, even with the CEL. I don't know if this makes any difference but my o2 sensor is a Bosch Universal, I hade a bosch on my b16 and had NO problems with it for over a year. Could the OBDII computer not like it. Also Is there a way that my computer is bad?? I have talked with local shops about this problem and I am at a Total loss. Any direction on troubleshooting this would be helpful.....Matt
Old Apr 8, 2004 | 11:32 AM
crxsirvtec's Avatar
Default Re: O2 Sensor Problem (mraudio13)
2 things..
what is the voltage of the o2 sensor..
high voltage = super rich..
Old Apr 8, 2004 | 12:15 PM
mraudio13's Avatar
Default Re: O2 Sensor Problem (crxsirvtec)
Actually i am going to test it tonight, The Code is for High voltage, that is all I know so far...Matt
Old Apr 9, 2004 | 06:50 AM
mraudio13's Avatar
Ok i hooked up a OBD Monitor and it said that my O2 sensor never activated, Is there a possability that I hooked the sensor incorectly, or would the ECU throw the code Immediatly if it was hooked up wrong??
Old Apr 9, 2004 | 07:21 AM
crxsirvtec's Avatar
maybe..
2 black wires are your heater wires.. they put out 12 volts..
that will give you a high voltage error..
white wire is your o2 signal.. green is common ground..
Old Apr 9, 2004 | 07:35 AM
mraudio13's Avatar
What would happen if I had the Green and white switched, would this be giving me all of my problems
Matt
Old Apr 9, 2004 | 08:08 AM
mraudio13's Avatar
Also, do you have to solder the connection, or can it be crimped??
Matt
Old Apr 9, 2004 | 12:09 PM
mraudio13's Avatar
Anyone??
Old Apr 9, 2004 | 02:22 PM
onePOINTsix's Avatar
if green and white were swtiched then it should throw a Low voltage code (sence Green=ground)
Old Apr 9, 2004 | 04:28 PM
crxsirvtec's Avatar
Default Re: O2 Sensor Problem (Sideout)
solder is better..
crimp is ok
Old Apr 10, 2004 | 04:57 AM
EE_Chris's Avatar
OBD2 doesn't seem to like Bosch O2 sensors....if you search, you'll see its quite a common trend.
Buy a new OEM piece, original connector and all, and then you won't have to worry about crimp/soldering, do white and green wire order make a difference and does brand make a difference.
LvN
Oct 11, 2008 07:46 AM
JibOnALib
Aug 25, 2005 08:54 PM
deftones0817
Jul 31, 2005 06:42 PM
apok
May 16, 2005 09:52 PM
spencedogg
13
Oct 28, 2003 06:45 PM
