d15b with d16a1 rods and pistons.
Old Apr 9, 2004 | 05:13 AM
dragaholic's Avatar
Default d15b with d16a1 rods and pistons.
A friend of mines did a rebuild on his d15b block by installing a set of rods and pistons from a d16a1 teg motor(suppose to bump compression a few points). Problem is the rods are too long and the pistons are a few millimeters out of the block. Can he use back his original rods? if not what rod can he use form another motor.
Old Apr 10, 2004 | 02:06 PM
dragaholic's Avatar
Default Re: d15b with d16a1 rods and pistons. (dragaholic)
BUMP
Old Apr 11, 2004 | 02:41 PM
SOHCHonda.com's Avatar
u need the vx rods.
the wrist pin location differences are whats causing the problem. u cant use 1.6 rods in a 1.5
utilizing the right rods will allow the benifit of the a1 slugs to be seen.
Old Apr 11, 2004 | 03:24 PM
RinBlue's Avatar
Default Re: d15b with d16a1 rods and pistons. (SOHCHonda.com)
OMG does even such a rebuild make sense? I remember throwing away good motors like that back in the day when i was into swaps!
But i guess do whatever floats your boat. Could you even feel that bump in compression your talking about?
anyway good luck in whatever you do
Vagitarian
Sep 14, 2012 02:14 PM
manniakk
Aug 8, 2007 12:41 AM
Sr420Det
Jul 14, 2007 04:59 PM
zdr262
Oct 9, 2003 08:33 AM
