fuel system problem
Old Apr 8, 2004 | 01:25 AM
egcivic94's Avatar
Default fuel system problem
I am flashing a code 43 acording to the manual it's the "fuel system" I took off my fuel rail to replace the FPR with a B&M and after that I had the problem, could it be a bad fuel pump or filter or maybe clogged injectors? any input would help
Old Apr 8, 2004 | 03:43 AM
civic-4-ges's Avatar
Default Re: fuel system problem (egcivic94)
Get a fuel pressure gauge, see where your pressure is set at. Most likely a bit too high.
Old Apr 8, 2004 | 03:24 PM
egcivic94's Avatar
Default Re: fuel system problem (civic-4-ges)
fuel pressure set at 40 psi at idle and 50 psi at WOT is that too high? I turned it high for the NOS
yywjsutherla
Honda CR-V & Element
Sep 13, 2017 12:38 PM
cyrix12
32
Oct 24, 2006 07:42 AM
se93
Dec 25, 2003 01:47 PM
Islander
May 19, 2003 11:08 AM
