Possible fuel issues with JG Intake manifold and TB
Old Apr 8, 2004 | 11:33 AM
Defi4nce's Avatar
Default Possible fuel issues with JG Intake manifold and TB
Just finished my new LS/VTEC engine yesterday and in the process of breaking it in.
BUT when its running it seems to be putting too much fuel into the engine, you can see vapor comming out of the exhaust and you can smell it.
The fuel system is stock, other than a fuel rail. It has a victorx manifold and TB.
My question is, could the larger volume of air be causing the car to compensate with more fuel? this has me worried, im afraid it will wash the rings.
Any one know of a problem like this?
Im most likely going to return back to stock until its broken in and ready for the turbo and tuning.
Any input would be much apreciated.
Thanks.
Old Apr 8, 2004 | 11:40 AM
crxsirvtec's Avatar
Default Re: Possible fuel issues with JG Intake manifold and TB (Defi4nce)
your new rail hold a bit more fuel..
but it is better to run on the richer side..
do you have a air/fuel gauge?
if not measure you o2 sensor voltage..
should be .4 to .6 Volts more voltage is ok, less is bad..
Old Apr 8, 2004 | 12:34 PM
Defi4nce's Avatar
Default Re: Possible fuel issues with JG Intake manifold and TB (crxsirvtec)
So should I be worried about the rings getting washed down?
Old Apr 8, 2004 | 02:05 PM
crxsirvtec's Avatar
no as long as your spark is there..
good wires.. even a msd coil will help..
Old Apr 8, 2004 | 02:21 PM
Defi4nce's Avatar
its got a new cap and rotor, and magnecore wires.
Will a thicker wire hinder spark?
Should i keep using the magnecors or go back to stock?
geek504
Jul 5, 2011 11:19 AM
gmctruck68
Apr 24, 2008 11:56 AM
ecks_fourttwo
Apr 26, 2005 10:19 AM
n2oisfun
Mar 1, 2005 07:10 AM
