Weird sound when turning
My CRX been making this knocking sound when i turn. Its comming from my drivers front side wheel. I know its not rubbing. It was the same wheel where my control arm got stuck to my chassis. But i got that fixed and its still making the sound. Could that have caused the knocking problem? Is my shock blown? Give me advice. Thanx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR »</TD></TR><TR><TD CLASS="quote">could be the axle knocking</TD></TR></TABLE>
I'm sure it's the cv axle, check to see if your boot is torn., if your lcky you might just need a new boot, make sure you pack it with grease, that would run you about $30, if you been running that way for more than a few months I would suggest getting a new a axle. that would run you about $75-$150, ggod luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivic94 »</TD></TR><TR><TD CLASS="quote">I'm sure it's the cv axle, check to see if your boot is torn., if your lcky you might just need a new boot, make sure you pack it with grease, that would run you about $30, if you been running that way for more than a few months I would suggest getting a new a axle. that would run you about $75-$150, ggod luck
Yup, but once it starts knocking its too late for a simple boot/grease job, the grit and dirt has already got up in there. Some places around here do cv joints for like 50-80 a side, slightly cheaper than a Autozone rebuilt axle.
</TD></TR></TABLE>Yup, but once it starts knocking its too late for a simple boot/grease job, the grit and dirt has already got up in there. Some places around here do cv joints for like 50-80 a side, slightly cheaper than a Autozone rebuilt axle.
Honduh@Love
Aug 30, 2005 02:18 PM
