Look @ my Alignment Numbers Plz.
Im only concerned with front end of my car.
Springs: 1.25" drop
shocks: stock
Camber kit: -1 to +3 degrees
Front left camber reading: -1.3
Front Right camber reading: 0
What could cause this? When i was settinng up the shocks and springs (comrpessing them) i tightened the front left a little less than the front right but only by about 5 turns or so (the bolt).
The camber kit is maxed out on the front left while on the front right it is about in the middle. Any ideas?? Does the lower shock fork installation have anything to do with it? Im guessing no....
Springs: 1.25" drop
shocks: stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Alex »</TD></TR><TR><TD CLASS="quote">Im only concerned with front end of my car.
Springs: 1.25" drop
shocks: stock
Is the car leaning to the left? Has it ever been wrecked?
Springs: 1.25" drop
shocks: stock
It slightly veers to the right.
When i bought it, it had cut springs 2" drop in front, no camber kit AND it went in a STRAIGHT LINE.
Could i correct it by putting some negatie camber on the front right tire?? Any suggestions or input welcome
Thats just the way its set. THe right side is set to 0 degrees while i NEED more POSITIVE camber to eliminate or decrease the -1.3 degrees on left side. THe camber kit is maxed out meaning i cant adjust it any further because it is at the end
sn00py415
May 17, 2007 12:20 PM
Quiks66
Sep 26, 2004 01:11 PM
Kamikaze-Kart
Mar 4, 2003 02:36 PM
