89 CRX Si Clutch + Engine Rumming?
Old Apr 10, 2004 | 08:38 PM
shaddr3's Avatar
Default 89 CRX Si Clutch + Engine Rumming?
I just got my 89 crx si back. When im shifting it into gears, it kicks in wayy too fast, and i doubt i'll pass inspection with it. Now to fix it, do I adjust the "Adjusting Nut" where the clutch cable goes into the ignition, so that its tighter?
Heres the diagram of what im talking about. http://www.binghamtonlife.com/...4.jpg
Also I my engine. I have a B16a engine swap put in before I bought the car. Right now when the engine is idleing in neutral, it rums up and down constantly. Does anyone know how to fix this?
Old Apr 10, 2004 | 09:29 PM
Fobtions's Avatar
Default Re: 89 CRX Si Clutch + Engine Rumming? (shaddr3)
u gotta turn the adjuster at the tranny end of the cable not inside the cabin, in your case u gotta loosen it up.
Old Apr 10, 2004 | 09:48 PM
shaddr3's Avatar
Default Re: 89 CRX Si Clutch + Engine Rumming? (Fobtions)
I turn the little adjusting bolt where the cable meets the tranny right? I losen it a bit, and that should stop it from kicking in and jumping 10 feet hwen im trying to put it in first gear or reverse >.<
mercury24
12
Aug 29, 2013 07:05 AM
dan89crxsi
Nov 25, 2003 04:24 PM
koticimage
Sep 8, 2002 08:53 AM
