ECU Help - USDM B18C5 in an EK w/ a CTR ECU. Need help - - -
OK, here's my situation. Bought a car w/ a USDM ITR B18C5 motor in it. The car is running w/ a CTR ECU. The ECU is picture below:
I also got w/ the car an ECU that the guy said was an Si ECU. Well, it's from 1996 (stamped Nov 1996 on it) so I have no idea what it is. Here's the pic of that ECU:
So I go and try to swap the "Si" Ecu in and the pins do NOT match. Sucks...I need to figure out an ECU that will work for me to pass smog since the CTR won't.
Here's the picture of the pins/sockets that are currently wired into the car:
Anyone have any ideas?
My goal is to be at a point where I can get a USDM ITR ECU or a P28 w/ Kenji program.
TIA for any help anyone can provide.
bump
found out the non CTR ecu is a d series non-vtec ecu.
Need insight into a clean way to get myself into a nice and clean USDM ITR or some or other ECU or ECU/Harness combo.
Thanks
Thanks
Use an obd22-21 ecu adapter and the USDM 97-98 ITR ECU. You can get that 22-21 ecu adapter from http://www.ecuadapters.com
-joe
-joe
ZEAL-SPORTS
Sep 7, 2005 04:53 PM
