removing the head
Old Apr 7, 2004 | 11:40 PM
MR. MIYAGI's Avatar
Default removing the head
me and my homie are tryn to take out the head... we tried to use a ratchet but that woldnt work.... we also tried an impact gun that didnt want to come out.... the 8 bolts are all hard to come out... do we need to use a breaker bar??? any suggestions...
Old Apr 8, 2004 | 02:31 AM
TimoneX's Avatar
New User
Default Re: removing the head (229motorsports)
What are you working on?
Aren't there 10 head bolts? They shouldn't be all that tight. I usually just start them with a 1/2" drive ratchet.
Old Apr 8, 2004 | 03:42 AM
civic-4-ges's Avatar
You may need a breaker bar, but if they were that tight, definately do not count on re-using them
Old Apr 8, 2004 | 05:36 AM
Crazydave's Avatar
Default Re: removing the head (civic-4-ges)
if the impact gun didn't take them off then pump up the pressure on your compressor a little more
that should have removed the bolts..but if you are having problems removing the head bolts with an impact gun... you probably have some other problems.
Old Apr 8, 2004 | 07:15 AM
Rod.'s Avatar
Default Re: removing the head (Crazydave)
just use a breaker bar that should take care of the job. that is what i used and it works
Old Apr 8, 2004 | 07:22 AM
jaxle's Avatar
it you used a shitty impact gun its no surprise that it didnt take them off. there are impact guns rated at as little as 75ft/lbs. use a breaker bar or get a better impact gun
Old Apr 8, 2004 | 09:41 AM
MR. MIYAGI's Avatar
we have a craftsmen impact gun... and it still didnt work... and we all ready tried a 1/2 driver ratchet didnt work... so we shouldnt reuse them... thanxs... were working on a b18c1.. were planin to send it to portflow... do u guyz have any other sugg. on where we should send the head???
Old Apr 8, 2004 | 10:06 AM
TimoneX's Avatar
New User
Portflow or Alaniz tech. Both do terrific work. Did you try a long breaker bar or a medium breaker bar with pipe on it?
Old Apr 8, 2004 | 10:11 AM
doublejz's Avatar
Default Re: removing the head (TimoneX)
I never had a problem pulling off a head, that the bolts were actually that tight, If you cant get them out with an air gun running 90psi then you really should becarefule cranking up the psis, if you snap one off your gonna be pretty much screwed unless a machine shop can get it out for ya. Try heating them up, or let the engine run until its hot. Heat usually always help
Old Apr 8, 2004 | 09:32 PM
MR. MIYAGI's Avatar
uhh... the motors already out of the car..
Old Apr 9, 2004 | 06:27 AM
jaxle's Avatar
just cos its craftsman doesnt mean its any good, smartass.
they have a 75$ model that has 75ft/lbs of torque, check its rating. also if you have an air compressor thats not supplying the correct amount of cfm the impact gun wont run at full capacity, nor will it run at full capacity if you have a constricting hose, either too skinny or too long.
Old Apr 9, 2004 | 01:36 PM
powerfulperformance's Avatar
Default Re: (jaxle)
Just use a long *** breaker bar. Make sure you break the bolts in the right pattern.
Old Apr 11, 2004 | 02:55 PM
MR. MIYAGI's Avatar
koo
InvaderTrax
Oct 6, 2006 06:28 AM
Captain Kyle
Feb 16, 2006 08:30 AM
RACEPAK
Oct 7, 2005 11:08 AM
grngsr01
Jun 15, 2004 07:14 PM
SPEED123
Nov 29, 2003 12:49 PM
