compression test... cyl. 4 bad... HELP
Old Apr 8, 2004 | 04:49 PM
aut0tek's Avatar
Default compression test... cyl. 4 bad... HELP
Hey guys... compression test as follows: (from tranny side to alternator side)
210-240-240-240
Any suggestions on what to do next? I did the "put oil in the cyl. then retest" and it went up to 240... I put like 1/2 a capful of oil in it... but maybe it was too much because it missed for like 2 mins of driving under acceleration afterwards... I guess it was cleaning out all the oil... u could see the smoke.
Anyhow... What to do next? leakdown test? I hope it's not rings on my new shiny JE pistons. :-/
Thanks,
Ratliff
Old Apr 8, 2004 | 07:40 PM
doublejz's Avatar
Default Re: compression test... cyl. 4 bad... HELP (aut0tek)
usually if you add oil and the numbers go up, it is the rings.
Old Apr 8, 2004 | 07:42 PM
SleepyHF's Avatar
Default Re: compression test... cyl. 4 bad... HELP (doublejz)
could that also be the headgasket aswell??
Old Apr 10, 2004 | 08:30 PM
aut0tek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">usually if you add oil and the numbers go up, it is the rings. </TD></TR></TABLE>
Yea... figures... Good thing I found a GSR block for $280.00 an hour away. ;-)
Use my crank rods and pistons and new rings and I'll get the GSR block girdle in return... YAYYYY ;-)
Ratliff
Fat Chick Magnet
Nov 24, 2006 02:50 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
nekoabandoned
Jul 24, 2006 03:39 PM
mafay2
Nov 11, 2004 07:34 PM
Witty
Jul 3, 2003 06:20 PM
