number one cylinder not igniting
Old Apr 11, 2004 | 06:45 PM
hontegra's Avatar
Default number one cylinder not igniting
checked for spark,theres spark.checked for gas theres gas,now i'm thinking the valves are opening at the right time on that cylinder.
Old Apr 11, 2004 | 06:57 PM
proformance's Avatar
Default Re: number one cylinder not igniting (hontegra)
why do you think the valves are not opening at the right time on that cylinder? camshafts usually dont wear on only one cylinder. usually if you have no spark in one cylinder, it will be something with either your spark plug having a cracked insulator, a bad plug wire (#1 cause), or a bad distributer cap. they are the only things that actually distribute spark to individual cylinders. if the rotor went bad it would take out all cylinders, same with the icm and coil. try replacing the wire plug and cap, and see if that helps. where did you check for spark, and how? depending on where you checked it, will determine what went bad.
Old Apr 11, 2004 | 07:03 PM
hontegra's Avatar
Default Re: number one cylinder not igniting (proformance)
changed wires,plugs,cap,resanator box.checked spark with the plug out still atached to the wire and grounded it.vales where adjusted by a buddy
cagarcia14
Apr 23, 2013 05:34 PM
thunderboy
Apr 24, 2010 08:39 AM
Nine0DA7
14
Sep 22, 2009 04:44 PM
aziaticvang
Jul 19, 2008 11:10 AM
EF9SIRJeff
Sep 8, 2005 08:05 PM
