smallest crank that fits in a D16 or D15?
Old Apr 9, 2004 | 08:07 PM
the jdmchop's Avatar
Default smallest crank that fits in a D16 or D15?
whould like to know whats the smallest?
D13?D14?
dont ask y
and if anyone has the stroke speck on them that wopuld be sweet
thanks
Dan-
Old Apr 10, 2004 | 09:38 AM
Default Re: smallest crank that fits in a D16 or D15? (jdmchop)
does anyone have any of these cranks for sale
Old Apr 10, 2004 | 01:41 PM
powerofdreams8's Avatar
I know that there was a D14A4 in the European Civic (6th gen). I have to assume the bore is the same as the other d-series so you could calculate the stroke based on 1395 cc displacement.
This guy claims to have had a 1.3 carbed motor in his civic in the UK. https://honda-tech.com/zerothread?id=744345
Old Apr 10, 2004 | 01:50 PM
Default Re: smallest crank that fits in a D16 or D15? (powerofdreams8)
yes i think i found out that the D!3 has a stroke of 76mm so thats sweet
the D13 crank should bolt to a D16 bolck no?
Old Apr 10, 2004 | 02:53 PM
JaeOne3345's Avatar
the d15 and d16 cranks cannot be interchanged due to journal issues. so the d13 crank into a d16 is doubtful.
Old Apr 10, 2004 | 02:56 PM
Default Re: smallest crank that fits in a D16 or D15? (JaeOne3345)
but can the d13 crank be put into a d15?
or can i bolt a Z6 head to a d13 block?
Old Apr 10, 2004 | 08:58 PM
dfoxengr's Avatar
you would definitely need the mains specs to know if that crank will fit
as to mounting the head. youd need pics of both head and block surfaces..
Old Apr 11, 2004 | 05:40 AM
Default Re: smallest crank that fits in a D16 or D15? (hybridvteceg)
hey hybridvteceg thanks for the positive advice!
does anyone have any specs on the D13 ?
like crank measurements
any pictures of a D13 or any specs fromthis motor would be sweet
Dann-
Old Oct 20, 2005 | 01:55 PM
Bense's Avatar
anyone know where i could find a d14a4 short block?
i'd also love to have a really short stroke on my d15/d16
Old Oct 20, 2005 | 04:31 PM
I Have an STD's Avatar
wrenchin'
Default Re: smallest crank that fits in a D16 or D15? (Gordon Liddy)
i reallyh hope u guys build the hell out of the head when you plan on revving these thing to like 12,000 rpm
Old Oct 21, 2005 | 06:16 AM
gotboostedvr6's Avatar
im looking for info also on d14 blocks
Old Oct 21, 2005 | 06:55 AM
RACEPAK's Avatar
Default Re: smallest crank that fits in a D16 or D15? (gotboostedvr6)
D14 REPRESENT. check out the sig
What do you want to know?
Old Oct 21, 2005 | 07:20 AM
Default Re: smallest crank that fits in a D16 or D15? (RACEPAK)
will the d14 crank fit in a d15b7 block? also what rods and pistens will be needed for 11/1 comp?
Old Oct 21, 2005 | 07:28 AM
RACEPAK's Avatar
mmm i dont know that sorry.
but here are some other details about the D14:
bore: 75.0
stroke: 79.0
valve spring langth
int: 58.70
ext: ^same
fq200turbo
Apr 19, 2008 01:33 AM
Bense
Sep 5, 2007 02:10 PM
alexsracing
Aug 8, 2005 04:51 AM
Br1anPham
Oct 5, 2004 08:42 AM
*Boostwerks*
May 10, 2002 08:05 PM
