Braking Shake???
Old Apr 7, 2004 | 09:15 PM
hair_rice's Avatar
Default Braking Shake???
Ok, when i am pressin on the brakes slowing down from high speeds (40-70mph) there is a vibration coming from the brakes, i wanna say the rear but not sure...what is this from? my guesses are maybe a rear alignment, discs need to be turned...i got a front end alignment done not to long ago so it cant be the front...any help would be great
Old Apr 7, 2004 | 09:33 PM
hondatim's Avatar
Default Re: Braking Shake??? (hair_rice)
sounds like warped brake rotors. Do you feel it in the steering wheel also? If so, coming from front rotors. If not, try pulling park brake and see if vibration occurs. If so, then coming from rears.
More probable from fronts though.
Old Apr 7, 2004 | 09:42 PM
mmuller's Avatar
Mad Scientist
Default Re: Braking Shake??? (hondatim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim &raquo;</TD></TR><TR><TD CLASS="quote">sounds like warped brake rotors. Do you feel it in the steering wheel also? If so, coming from front rotors. If not, try pulling park brake and see if vibration occurs. If so, then coming from rears.
More probable from fronts though.</TD></TR></TABLE>
Old Apr 7, 2004 | 10:03 PM
hair_rice's Avatar
Default Re: Braking Shake??? (mmuller)
thanks man
Old Apr 7, 2004 | 10:41 PM
DaChoZn1's Avatar
If it only happens when you apply the brakes its definately your rotors. Its times to have them resurfaced or replaced.
Old Apr 8, 2004 | 05:31 AM
Crazydave's Avatar
Default Re: Braking Shake??? (DaChoZn1)
Also look at your rotors.. if they have leopard spots.. don't resurface them... get new ones.. leopard spots = ruined rotor.
Old Apr 8, 2004 | 11:50 AM
jazz215's Avatar
just a question, why are the rotors ruined if they have the heat spots on them? couldnt it just be resurfaced?
Old Apr 8, 2004 | 02:01 PM
Chiovnidca's Avatar
Default Re: (jazz215)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazz215 &raquo;</TD></TR><TR><TD CLASS="quote">just a question, why are the rotors ruined if they have the heat spots on them? couldnt it just be resurfaced?</TD></TR></TABLE>
Those little spots are harder than the metal around them, they don't cut very well and just come back anyway.
Old Apr 8, 2004 | 06:12 PM
94gsr's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Those little spots are harder than the metal around them, they don't cut very well and just come back anyway.</TD></TR></TABLE>
Heat spots do not "just come back" unless they are not completely cut out, and/or the rotors are below spec.
Old Apr 8, 2004 | 06:49 PM
mmuller's Avatar
Mad Scientist
Default Re: (94gsr)
just get new rotors, they are like $20 each
Old Apr 8, 2004 | 08:02 PM
Jaesung's Avatar
Default Re: (mmuller)
autozone lifetime rotors way to go.
Old Apr 8, 2004 | 08:24 PM
Sliced Beard's Avatar
Default Re: (Jaesung)
especially when you work at auto zone and you get madd crazy discounts ands still get warranty
Old Apr 9, 2004 | 01:33 AM
hair_rice's Avatar
Default Re: (dirtyd463)
when u get new rotors u need to get them surfaced right, then i can put them on myself?
Old Apr 9, 2004 | 02:30 AM
94gsr's Avatar
Default Re: (hair_rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hair_rice &raquo;</TD></TR><TR><TD CLASS="quote">when u get new rotors u need to get them surfaced right...</TD></TR></TABLE>
Surfacing of new rotors is unnecessary.
Old Apr 9, 2004 | 03:26 AM
Chiovnidca's Avatar
Default Re: (94gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr &raquo;</TD></TR><TR><TD CLASS="quote">
Surfacing of new rotors is unnecessary.</TD></TR></TABLE>
Honda reccomends new rotors be surfaced on the car. It is necessary sometimes.
Old Apr 9, 2004 | 05:00 AM
94gsr's Avatar
I have heard of the recommendation, but I can't substantiate it. I've replaced rotors on everything from Honda's to Ford F-350's, on my own , friends' & customers' vehicles, and have never surfaced a new rotor.
Old Apr 9, 2004 | 11:47 AM
Chiovnidca's Avatar
Default Re: (94gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr &raquo;</TD></TR><TR><TD CLASS="quote">I have heard of the recommendation, but I can't substantiate it. I've replaced rotors on everything from Honda's to Ford F-350's, on my own , friends' & customers' vehicles, and have never surfaced a new rotor.</TD></TR></TABLE>
The only time i'll turn a new rotor is if there is a pulsation from them. Ive had 3 or 4 over the years that it was the only way to get rid of very slight brake vibrations. (Very picky customers.) I think Honda says to do it on all of them to cover there *** on warranty repairs.
Old Apr 9, 2004 | 04:23 PM
hair_rice's Avatar
so i could basically go get new rotors and throw em on?
Old Apr 9, 2004 | 06:23 PM
Crazydave's Avatar
Default Re: (94gsr)
Heat spots do not "just come back" unless they are not completely cut out, and/or the rotors are below spec.</TD></TR></TABLE>
Heat spots do not just exist on the surface of the rotor.
Even though you resurface the rotor, you don't change the metalurgical change that has already occured. The problem will quickly come again.
Not only that, but the brake pads that you use on a damaged rotor like that won't last as long either.
Old Apr 9, 2004 | 06:42 PM
mmuller's Avatar
Mad Scientist
Default Re: (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">
Not only that, but the brake pads that you use on a damaged rotor like that won't last as long either. </TD></TR></TABLE>
yep, that is exactly right. i had burned rotors, put new ones in with same pads and the burns came back.sanded them down, put new pads and voila!no burns
ep3rez
21
Jun 7, 2010 05:53 AM
globy123
16
Aug 21, 2007 05:23 PM
dcb284
May 19, 2005 06:51 AM
miksew
Feb 6, 2004 01:23 PM
bren1339
16
Oct 15, 2003 01:08 PM
