vss question
Old Apr 8, 2004 | 08:37 AM
spaceman's Avatar
Default vss question
when i put a b16 into my 88 crx,i removed the vss so i could put my stock speedo cable into the tranny..was that the correct method?..im finding out from someone that if i dont use the vss that the motor came with then i wont get vtec to work
Old Apr 8, 2004 | 09:31 AM
spaceman's Avatar
Default Re: vss question (spaceman)
anybody wanna help me out with some info please?..i never knew about this i thought i researched everything about doing a b16 into 88 crx si...so what should i do now?
Old Apr 8, 2004 | 11:12 AM
limpy's Avatar
i have a b16 in my crx too and I have the stock spedo cable and my vtec works. I may be wrong here but i think the vss is only needed to run the sir guage cluster, which needs an electronic speed sensor not cable.
Old Apr 8, 2004 | 11:30 AM
crxsirvtec's Avatar
Default Re: vss question (limpy)
with the crx cluster.. the cable drives the speedo, then the cluster outputs a vss signal to the ecu, giving your ecu a vss signal for VTEC..
But you should get a chip, because with those ecu's they will shut off at 115 mph!!
check out http://www.racingchips.com good prices and custom made chips for you..
spaceman's Avatar
alright thanks dood just makin sure i did the right thing
ben.batiste
Jan 7, 2010 07:20 AM
90crxdxb16
Sep 25, 2006 03:30 PM
vitrox
Nov 7, 2004 09:02 PM
JohnCRX
Jul 29, 2004 09:00 AM
