redline from the start up
Old Jun 22, 2004 | 09:27 AM
gato5254's Avatar
Default redline from the start up
I put my intake manifold on yesterday. I'm getting another code from my VSS(vehicle speed sensor) that's why my speedo was jumping around. I did some reading up on it, and everyone said that more than likely it went bad because of an oil leak. None the less, my car won't run. I can start it up and everything but the engine just revs up without mt touching the gas, like all the way up. i tried to put it in gear, and the rpms dropped down to idle for a split second, then jumped right back up again. The KS( Knock sensor) is bad. I soldered it up but I'm still getting the code. This my b16a2 running a integra type r ecu and the intake manfold is a tsunami. If it matters it's in a 98 civic ex. any help be great
Old Jun 22, 2004 | 09:32 AM
B20fun's Avatar
Default Re: redline from the start up (gato5254)
It seems like there would need to be either a really big vacum leak or the throttle plate is stuck open for some reason. That is really high rpm for not touching the gas.
Old Jun 22, 2004 | 12:07 PM
gato5254's Avatar
Default Re: redline from the start up (B20fun)
If the gasket between the manifold and the block was leaking do you think that would happen? Also would the VSS or KS have anything to do with it?
Old Jun 22, 2004 | 12:38 PM
Kamin's Avatar
you didnt replace the gasket did you?
YES the gasket between the IM and the block WILL cause that problem. the 2 surfaces need to be completlety clean before the new one is applied. make sure you torque the bolts to the correct spec and in order.
no the VSS or KS will not cause this problem, you probably knocked those plugs loose when changing the manifold.
Old Jun 22, 2004 | 01:07 PM
gato5254's Avatar
Default Re: redline from the start up (Kamin)
I did replace the gasket, however I couldn't get all the old gasket off from around the bolts on the block. What do you recomend to get that off? And is there a specific type of gasket glue I should use or that is recomended? Also, before I changed my intake manifold my engine would pop as I reached about 6,000 rpms or so. Do you think the KS would have anything to do with that? It felt just like the rec limiter kicked in but I am running a JDM Integra Type-R comp. so I know the redline is set higher. What could be causing that?
Old Jun 22, 2004 | 05:24 PM
Jimmy's Avatar
Global Moderator
Try using ''gasket remover''
Your idle is probally being caused by the IM gasket.
If so much of a ''hair'' is messed up on that gasket it can cause a vaccum leak.
Old Jun 24, 2004 | 05:51 AM
b16jdm's Avatar
Default Re: (Jimmy)
Does that affect performance at all or is it just a hassle to drive?
Old Jun 24, 2004 | 06:22 AM
Kendall's Avatar
You can also get the gasket material off with a razor blade.
Old Jun 24, 2004 | 06:25 AM
crazykid's Avatar
Default Re: (b16jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16jdm &raquo;</TD></TR><TR><TD CLASS="quote">Does that affect performance at all or is it just a hassle to drive?</TD></TR></TABLE>
I had the same problem with my H22, and yuo NEED to get the gasket off there, it wont run right, and will idle like that. take it back apart, and clean it all up.
Sorry, thats the only answer....
Old Jun 25, 2004 | 06:54 AM
PnX-R's Avatar
I know you probably already figured it out but, just thought I'd throw in my 2cents.. I learned that if there's a vacuum leak, spray carb cleaner around the intake manifold and throttle body. If idle drops, you found your problem..
Old Jun 26, 2004 | 08:05 AM
gato5254's Avatar
hey everyone thanks for your help on this
Old Jun 26, 2004 | 08:06 AM
gato5254's Avatar
also where can i get a knock sensor mine is broke
Old Jun 26, 2004 | 08:16 AM
gsrdragster's Avatar
can anyone in here tell me how to drop a 95gsr into a 90 dx htch(cable tranny) without having to change the tranny? i am stuck!
Old Jun 26, 2004 | 08:17 AM
Kamin's Avatar
Default Re: redline from the start up (gsrdragster)
are you serious? dude use the god damn search button
https://honda-tech.com/zerosearch
Old Jun 26, 2004 | 08:23 AM
can some one help me out because i already know bout the hasport efb2 change over mount but i dont know how sturdy the mount is. the gsr that i am dropping into my hatch is worked to the ***** and dont want know clutch problems and dont want to use the b16 tranny because the gears are to short and i dont want to use a ls tranny because the gears are to long. i need the gsr tranny to go with my set up.and no i do not want to buy a 92 hatch ! i love the light weight dx
Old Jun 26, 2004 | 08:27 AM
what do you mean use the god dam search button...."DUDE!" this is my first time on this web sight...."DUDE!"
Old Jun 26, 2004 | 08:30 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrdragster &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean use the god dam search button...."DUDE!" this is my first time on this web sight...."DUDE!"</TD></TR></TABLE>
well then im educating you newbie.
you dont ask questions in other peoples threads that have NOTHING to do with the topic
you dont ask questions that can be answered if you SEARCH FOR YOURSELF
miguey310
Mar 2, 2013 06:47 PM
ej2civoke
Mar 14, 2010 04:47 PM
aeenox
13
Jun 18, 2009 07:31 PM
integRated109
Jul 5, 2002 02:02 PM
