Difference Between PR3 and Pr4 ecu's
Old Jun 24, 2004 | 04:37 AM
jondancer's Avatar
Default Difference Between PR3 and Pr4 ecu's
ihave a 91 crx with a obdo b16 set up and when i use a pr3 ecu
my car randomly cuts out, when the check engine light comes on the light just
stays solid, i have tryes 3 pr3 ecus all the same porblem.
if i use a pr4 i have no problem but no VTEC. what are the diffent things the pr3
contols that the pr4 dont? thanks
guys.
any info is helpfull
Old Jun 24, 2004 | 06:24 AM
Kendall's Avatar
The PR3 has the capabilities of controlling VTEC, and can use input from the knock sensor, where as the PR4 cannot. Check to figure out exactly which codes the PR3 is throwing and we'll know how to better help you.
Old Jun 24, 2004 | 08:05 AM
jondancer's Avatar
Default Re: (Kendall)
the pr3 only flashes a solid code(faulty ecu?) never flashes a code
the pr4 flashes a 67? which does not make sense.
Old Jun 25, 2004 | 08:02 AM
jondancer's Avatar
Default Re: Difference Between PR3 and Pr4 ecu's (jondancer)
ANYONE???????????????
sloweh3
Sep 26, 2016 10:18 PM
MIGPA26
Apr 2, 2010 09:35 PM
pnoipj89
Mar 22, 2008 02:38 PM
nousername
20
Jun 28, 2004 12:32 PM
WAFFLES
Aug 7, 2002 09:14 AM
