Motor has trouble starting
Old Jun 20, 2004 | 01:37 PM
rob42386's Avatar
Default Motor has trouble starting
When i go to crank my motor it turns over, and all, but it wont crank on the first attempt. It most the time will on the second time.
Then sometimes i go to crank it, and it wont start at all, it will just turn over, and not start, but then if i leave it for a while and come back it will start up.
Then i was on a long trip and stopped at the gas station, and turned it off, and it would not start, so after it was even warmed up!!!
Old Jun 20, 2004 | 01:41 PM
Jaesung's Avatar
Default Re: Motor has trouble starting (rob42386)
most likely your timing belt is skipping a tooth. might want to look into that.
Old Jun 20, 2004 | 09:35 PM
rob42386's Avatar
For real?? sometimes it starts on the first try when it is warmed up, i was thinking maybe the main relay???? or something, maybe also because its a vtec e motor and it doenst have its computer to run it, it has a si's, maybe its some crazy **** to crank it while it has 12 valves????
also maybe the fuel pump, but it eventually cranks so i dont know??
Old Jun 25, 2004 | 07:57 AM
PnX-R's Avatar
I'm not too sure what to tell you but.. If takes a long crank for it to start, your problem is your fuel pressure regulator..
mynameizstitch
Mar 17, 2012 10:55 AM
tlarimer
Jul 20, 2009 03:18 PM
crxcess
Jun 10, 2006 06:05 AM
hmonglonertim
Apr 26, 2002 02:12 PM
