B18C1/B16A2 HEAD
Old Jun 21, 2004 | 05:00 AM
boostedH22Teg's Avatar
Default B18C1/B16A2 HEAD
i got a question? 1 have a 00 civic si.. im thinking droping a 98 b18c1 block and use the 16a2 head. wat u guys think is it worth it?
Old Jun 21, 2004 | 06:16 AM
92b16vx's Avatar
Not unless you replace the pistons. You lose some compression because the B16As combustion chambers are bigger.
Old Jun 21, 2004 | 09:27 AM
Malgerus's Avatar
Default Re: (92b16vx)
You lose about .2 compression (at least I know this is the case with the B16A head [first gen])... either get the head milled or get a thinner headgasket and you're good. The ITR head is a worked over Pr3 B16A head anyways.
Old Jun 21, 2004 | 10:21 AM
Default Re: (Mr. S)
cuz. wat im tryin to do is b18c1 block b16a2 head then boosted. cuz b16 dont have much tq .
here's my turbo set up....t3t4,head gasket,440 injector, 255 fuel pump, apex s-afc
just want to boost 9psi
Old Jun 21, 2004 | 10:59 AM
92b16vx's Avatar
Default Re: (boostedH22Teg)
Than just take the .2 compression hit, use an OEM headgasket
Old Jun 25, 2004 | 10:53 PM
crazyzcvtecdriver's Avatar
Default Re: B18C1/B16A2 HEAD (boostedH22Teg)
you may loose about .2 in your compression but you will still have more torque than your 16. but do use the 18 block i just didi the same swap to my crx. i went from a 16.0 to a 15.2 in 1/4.
Old Jun 25, 2004 | 11:23 PM
EgxHaTcHxGsR's Avatar
i don't think it matters cuz all i kno is that it makes yur car go faster then gsr block with gsr head. Why? I have no fukkn clue. lolz
Old Jun 26, 2004 | 08:53 AM
wongf22b2's Avatar
Default Re: B18C1/B16A2 HEAD (EgxHaTcHxGsR)
Boost it up.
Old Jun 26, 2004 | 09:39 AM
Thrillhouse's Avatar
Default Re: B18C1/B16A2 HEAD (crazyzcvtecdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyzcvtecdriver &raquo;</TD></TR><TR><TD CLASS="quote">you may loose about .2 in your compression but you will still have more torque than your 16. but do use the 18 block i just didi the same swap to my crx. i went from a 16.0 to a 15.2 in 1/4.</TD></TR></TABLE>
I hope im reading this wrong. You are running 15's with a 1.8 block and b16 head in a CRX? Or a poor mans R? I hope not
btlancaster
23
Aug 28, 2008 04:43 PM
probenator
Oct 12, 2006 02:33 PM
yh23
Aug 6, 2005 09:58 AM
P_t0wn
May 2, 2005 08:15 AM
DSR!
Oct 22, 2004 04:53 AM
