charcol canister 99civic si
Old Jun 23, 2004 | 09:51 AM
9seccivicsi's Avatar
Default charcol canister 99civic si can it be removed??????
i was wondering if it is ok to take out that charcol canister thtat sit along the fire wall? also if i were to take it out would i just put a breather filter over the line that goes to the fuel tank?
Old Jun 23, 2004 | 10:02 AM
Two_K Si's Avatar
Default Re: charcol canister 99civic si can it be removed?????? (2.0 boostified)
Why would you want to remove it? Is it not functioning properly?
Old Jun 23, 2004 | 07:08 PM
it is in a sfwd car and i dont see there being a reason for it beeing there but i am not sure if i can just take it out or does it have to bee there?
Old Jun 24, 2004 | 05:39 PM
any one???
Old Jun 24, 2004 | 07:40 PM
ILLEGALB16's Avatar
your charcoal-evap canister is something that isnt hurting anything. i have a hondata and that eliminates the evap sylnoid that is on your fuel rail, which is hooked up to the evap canister, so i'm not using it either, but i figure its hooked up to the tank, so i should just leave it, plus i don't think it weighs anything. if you figure out a safe way to take it out, let me know. i think all my friends with track only drag cars, stripped to the bone, still have them in, i'll call around tomorrow to see,
Old Jun 25, 2004 | 06:32 AM
PnX-R's Avatar
Why would you want to remove the EVAP canister?.. Isn't it illegal? And I'm pretty sure you'll just end up with a CEL..
Old Jun 25, 2004 | 10:43 AM
wel the car will see the street every once in a while but i want to remove the canister for more room in the engine bay!
Old Jun 25, 2004 | 07:28 PM
taz77's Avatar
New User
Default Re: (2.0 boostified)
you can physically do it...
it will be illegal if you drive it on the street...
you will throw a code... or very likely. i don't know how often the evap monitors run on hondas
u will get fuel vapors coming out of the breather... might burn if the vapors gets concentrated towards the exh manifold... especially on a hot day...
u might get fuel puddles out of the breather if u overfill the tank
your car will smell like fuel on a hot day...
if u can live with those, u can do anything u really want. if you're just looking to save some space... figure out how to relocate the evap canister rather than remove it.
Old Jun 25, 2004 | 11:01 PM
**** it i guss it is staying in
Old Jun 26, 2004 | 12:07 AM
IVI's Avatar
IVI
rip it out if you want, i dont have mine hooked up but its still there. you wont get a cel for it. it has only to do with emmisions. i have a diffrent IM so i dont have the purge valve.
DelSolMike
Oct 6, 2013 08:26 AM
g2turbo
Aug 21, 2013 09:08 AM
jdmjin
Jan 2, 2008 07:29 AM
funtak
Jul 22, 2007 04:43 PM
racekar
Oct 12, 2004 11:47 AM
