Alignment Degree to Inch?!
Old Jun 22, 2004 | 03:19 PM
ion_four's Avatar
Default Alignment Degree to Inch?!
How does one convert from degrees to inches, since many people refer to toe measured this way ex. 1/8" toe out, as opposed to 1º toe out? Since alignment seems to be measured from the rim, it seems ridiculous to specify settings in inches, since this is dependent on the wheel (and tire) size, if I'm understanding this.
If I know that my toe setting (as measured on an alignment rack) is -.023º and I have a 195/60/14 tire (outside diameter ~23") do I say (23"*3.14)/360 = 1º in this respect, so that this would be -.005"?!
Or is the measurement in inches contingent on some invisible path of suspension movement/ adjustment?
I'm just wondering because I have front toe readings of -.07ºL and -.10ºR, when the negative toe is easily visible and somewhere around 1/4" total toe out (yes, too much) and converting the degree measurement (from the alignment rack) shows a very, very tiny amount of negative toe.
Old Jun 22, 2004 | 11:21 PM
ion_four's Avatar
Default Re: Alignment Degree to Inch?! (ion_four)
So, does anyone know this? How would 1º toe out be equated to X" toe out, or vice versa?
Old Jun 23, 2004 | 06:00 AM
JimBlake's Avatar
I'm guessing the toe distance is based on the rim diameter, not the tread diameter. So in your case...
Toe = sin(angle) * 14"
Toe = sin(0.1deg)*14" = 0.0244"
angle = asin(toe/14")
angle = asin(0.25/14) = 1 degree
Something doesn't add up. Are you sure you're "seeing" toe, or maybe camber?
vdub08
Aug 9, 2010 09:06 PM
VTECROAR96typeR
Suspension & Brakes
Apr 4, 2010 10:11 AM
blinger
Oct 18, 2007 06:36 AM
97EXB18C
14
Jul 28, 2005 09:05 PM
D16Z6racing
Jan 4, 2004 10:31 AM
