Converting automatic PR3 ecu to manual...
Old Jun 22, 2004 | 03:27 PM
UNDER PRESSURE's Avatar
Default Converting automatic PR3 ecu to manual...
What are the benifits?... By changing the jumper points will this up the redline to 8200 from 7500, or does it just change the fuel maps? I searched and all I can find is how to convert it but it doesn't explain what it accually does.
TIA
Old Jun 23, 2004 | 09:10 AM
Default Re: Converting automatic PR3 ecu to manual... (UNDER PRESSURE)
Anybody?
Old Jun 23, 2004 | 09:56 AM
SkRiBLaH's Avatar
i think you must just remove teh resister RP17 and thats that.
Old Jun 23, 2004 | 10:25 AM
Default Re: Converting automatic PR3 ecu to manual... (SkRiBLaH)
Wrong resistor. I know how to do it but what are the benifits?
Old Jun 23, 2004 | 11:23 AM
Joseph Davis's Avatar
No CEL 19. **** if I know that the revlimit differences are, I've never played around with one. I'd ASSUme the revlimit is the exact same, you just don't have a slushbox shifting before you reach it.
Old Jun 23, 2004 | 11:43 AM
Default Re: Converting automatic PR3 ecu to manual... (J. Davis)
So red line stays the same the only thing that changes is fuel maps?
Old Jun 24, 2004 | 07:17 AM
Anybody else?
Old Jun 29, 2005 | 01:00 PM
crexer's Avatar
Bump for the same question I have everything ready to do it but I wanna know if it will change the redline as well. What do you mean CEL 19? Has anyone actually moved the 2 spots?
Old Jun 29, 2005 | 01:41 PM
PURPLETERROR aka BIGMATT's Avatar
You have to move a resistor, and run a manual program.
Old Jun 29, 2005 | 05:06 PM
drdisco69's Avatar
Nothing in the maps change, there is only one set of maps in the chip. It just keeps the program from getting pissy about the lockup solenoid not being present. You will still need to change the rest of the stuff, like rev limiter and maps.
fryman
10
Mar 24, 2023 01:40 PM
deeweezy187
Aug 19, 2007 10:37 AM
UNDER PRESSURE
12
Jun 29, 2005 01:47 PM
Jul 13, 2003 07:42 PM
civiksi
Jun 7, 2002 05:41 PM
