rust around a rotor?
Old Jun 21, 2004 | 01:45 PM
es_squared's Avatar
Default rust around a rotor?
just noticed this on my rear rotor, it looks like rust on the surface or something and some parts of hte surface are a bit rougher , not sure what it is exaclty. .
i can take a pic if itll help
Old Jun 21, 2004 | 02:19 PM
Tushner's Avatar
Default Re: rust around a rotor? (es_squared)
Rust on the brake rotor?
Don't worry about it. Drive for a minute and it is gone.
Old Jun 21, 2004 | 02:20 PM
timmy8151's Avatar
Rust on rotors is very common. However, once you start driving the rust will go away. I have rust on my rotors every morning and it doesnt worry me.
Old Jun 21, 2004 | 03:37 PM
es_squared's Avatar
Default Re: rust around a rotor? (timmy8151)
ya it doesnt seem liek its goign away tho hehe
Old Jun 21, 2004 | 04:48 PM
Two_K Si's Avatar
If it is the part of the rotor that does not come in contact with the brake pads, you can hit the rotors with some hi-temp silver spray paint. That way your rotors will stay bling.
Old Jun 21, 2004 | 04:56 PM
Tushner's Avatar
Default Re: rust around a rotor? (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">If it is the part of the rotor that does not come in contact with the brake pads, you can hit the rotors with some hi-temp silver spray paint. That way your rotors will stay bling.</TD></TR></TABLE>
Hahaha...
Old Jun 21, 2004 | 04:58 PM
es_squared's Avatar
lol.. sure,.
Old Jun 21, 2004 | 05:57 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared &raquo;</TD></TR><TR><TD CLASS="quote">ya it doesnt seem liek its goign away tho hehe </TD></TR></TABLE>
then you have some troubleshooting to do. take the car for a drive, hit the brakes, see if the rust is still there. if so then do more driving, pull the ebrake and see if rust is still there. The pads may not be coming into contact with the rotor. I had a similar problem after doing a rear disc conversion. I ended up replacing one of the brake lines and it was fine after that.
Old Jun 21, 2004 | 07:06 PM
es_squared's Avatar
Default Re: rust around a rotor? (kommon_sense)
ok ill give tyhat a shot
also is it worth upgrading the rear rotors? cuz i just got some powerslots for the front.
thaseint
Suspension & Brakes
May 1, 2007 09:45 PM
globy123
11
Jan 31, 2007 02:26 PM
GreenMachineRex
Apr 15, 2005 11:39 AM
CG_EJ8
14
Nov 9, 2004 11:19 AM
mobstersmoke
Jul 28, 2004 09:55 PM
