changed fuel filter, still bogging!!!!!!!!!!!111111
Old Jun 24, 2004 | 02:55 PM
coupey's Avatar
Default changed fuel filter, still bogging!!!!!!!!!!!111111
ok so when accelerating, my car bogs so bad....like it will feel like the car just completely loses power, regains it, then loses it, it doesnt do this when the car is cold, and maybe like every 5th stop light, it wont do it....ive changed fuel filter, spark plugs, wires, distributer....what could it be?
timing? injectors? anybody help im so frustrated haha...and it did this before i was turbo so i know its got nothing to do with that
Old Jun 24, 2004 | 05:03 PM
coupey's Avatar
anybody?
Old Jun 24, 2004 | 10:45 PM
speedymon's Avatar
Default Re: (nine nine si)
Check timing, leaking wires, o2 sensor, coil, ignitor. Swap out distros to isolate the coil and ignitor. I had that same problem and i bought a new O2 sensor from groupbuycenter.com, NGK.
Old Jun 24, 2004 | 10:51 PM
Sack Master's Avatar
Default Re: (speedymon)
If you've done all that I'm leaning toward o2 sensor too.
Old Jun 25, 2004 | 12:13 AM
ThisLittleSleepeR's Avatar
Default Re: (Sack Master)
try tps sensor, they do that when they are bad or dirty, also clean the ivac? i forgot the name but its on the back of the manifold. simple things to try to help you out.
Old Jun 25, 2004 | 05:23 AM
coupey's Avatar
ill have to try these, thanks a lot, ive been told its probably my timing, any more suggestions would be helpful, thank yall
Old Jun 25, 2004 | 08:18 AM
PolySquared's Avatar
I had the same problem. I just replaced the cap, rotors, wires, plugs, and ignitor coils. Bog was %100 gone.
Old Jun 25, 2004 | 10:25 AM
coupey's Avatar
Default Re: (PolySquared)
how much were the coils
Old Jun 25, 2004 | 02:32 PM
coupey's Avatar
changed map sensor, no luck
Old Jun 25, 2004 | 03:52 PM
suspendedHatch's Avatar
What about the sock on the fuel pump.
Old Jun 25, 2004 | 07:18 PM
taz77's Avatar
New User
you know what? honestly, it'll be cheaper to just take it to a dealership and have them diagnose and fix the problem than to parts-swap.
dealer - $115 to diagnose, then the cost of the part to fix the problem
parts swap - $$$ to replace the fuel filter/pump, fpr, distributor, coil, igniter, tps, map, o2, ect, iat, etc... there's just too many things that can cause those symptoms. (actually, some i listed really aren't your problem, but someone is going to, or has, suggested). unless you have a multimeter, and/or vacuum pump, scan tool to diagnose, it's not worth it to swap parts.
Old Jun 27, 2004 | 07:49 AM
coupey's Avatar
ok i think im gonna replace the whole dizzy, ive been reading and the distributor has caused the hesitation like i am having
Old Jun 27, 2004 | 12:50 PM
Chiovnidca's Avatar
Poke and hope. Good luck.
Old Jun 27, 2004 | 05:08 PM
PnX-R's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (nine nine si)
Here's a little something.. You said it doesn't do this when the car is cold.. So that must mean that the ECU hasn't started to adjust air/fuel ratios according to the O2 sensors..
What I would to is plug a Scan Tool into the vehicle and watch the O2 sensor and see how fast they're responding and continue diagnosing from there..
Old Jun 27, 2004 | 05:47 PM
BouncinOffTheRevLimiter's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (PnX-R)
Do your revs drop when this happens? Because if not it could be your clutch slipping. The clutch on my lude is like then when I first drive it on a cold day. I will slip/catch/slip catch for alittle while. Then it is fine...maybe it is the other way around and your clutch is hot? Because it will slip when its hot too.
Old Jun 28, 2004 | 08:07 AM
coupey's Avatar
i know what a slipping clutch feels like and this is def. not my clutch
Old Jun 30, 2004 | 07:45 PM
then..i am agreeing with pnx..check your O2 .and if thats not it. Then for gods sake bring your car to a dealership.
Old Jul 4, 2004 | 12:24 PM
coupey's Avatar
timing was a little off but nothing major, fixed it and nothing, im gonna do o2
Old Jul 4, 2004 | 09:06 PM
RTE117's Avatar
I had a problem like this a few months ago.. Mine was from my fuel pressure. What fuel pump and FPR are you using? Also is your fuel line to the rail modified at all?
Old Jul 5, 2004 | 08:23 AM
coupey's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (IDriveAHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda &raquo;</TD></TR><TR><TD CLASS="quote">I had a problem like this a few months ago.. Mine was from my fuel pressure. What fuel pump and FPR are you using? Also is your fuel line to the rail modified at all?</TD></TR></TABLE>
walboro 255 and stock FPR, and no its not modified
Old Jul 5, 2004 | 08:32 AM
RTE117's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nine nine si &raquo;</TD></TR><TR><TD CLASS="quote">walboro 255 and stock FPR, and no its not modified</TD></TR></TABLE>
Do you have a fuel pressure gauge? I had trouble getting my fuel pressure down with a B&M FPR when I installed my Walbro 255.
Old Jul 5, 2004 | 08:58 AM
Chiovnidca's Avatar
Do you have a fuel pressure gauge? I had trouble getting my fuel pressure down with a B&M FPR when I installed my Walbro 255. </TD></TR></TABLE>
I had the same problem with my Holley pump. Made it run rich.
Old Jul 5, 2004 | 09:48 AM
coupey's Avatar
it has nothing to do with my fuel pump because it did it when i had the stock one in.
Old Jul 5, 2004 | 01:08 PM
speedymon's Avatar
Did you swap the dizzy yet? If not get another o2 in there. Or get a voltmeter and check to see if the voltage off the o2 is within specs. I did that and saw that my o2 was responing slowly. Good luck.
Old Jul 5, 2004 | 06:50 PM
4inspeed's Avatar
do you have a smell of gas? or anything like that... i had the same problem but mine was from a faulty vafc.
you might be running really rich. probly not your problem but wouldnt hurt to check out.
