Issue's W/ B20 Swap. Help needed?
Well finally got the hatch out of the shop.
93 hatch w/ b20 vtec swap.
1 Big issue.
In every gear, right before its supposed to cross over into vtec is studders as if it was hitting the rev limiter then after about 4 or 5 times bouncing right before vtec it will then cross over and be fine.
This happens in every gear, with the gas stomped for WOT and even with a gradual increase in RPM's.
Can anyone tell me why this is happening?
My boy/ Strauss Mechanic said it could be a lack of fuel issue...
any insight?
1 Big issue.
any insight?
HMM....SOUNDS STRANGE...WHAT SIZE INJECTORS R U USING AND WHAT ECU....I HAVE A q FOR YOU ALSO....WHAT MOTOR MOUNTS DID YOU USE IN UR SWAP...IM USING all gSR MOUNTS BUT I CAN GET IT TO SIT RIGHT IN MY 95' CIVIC COUP?....THX DUDE...WE COULD PROLLY HELP EACHOTHER -SWIFT
