For the TECH here, need help badly!
Old Jun 30, 2005 | 10:10 AM
Mr_Q's Avatar
Default For the TECH here, need help badly!
the gear on my 98 automatic prelude will not select itself, what i mean by it, is that when i'm on drive you know how the gear suppose to just select itself when the rpms hit certain number..well mine would just stay there and the engine just rev up, i would have to like tab the shifter up and down a lil' bit for it to switch, but sometime it switch to a lower gear instead of to the next gear..at the shop they would pull up this two codes: P070 TRANS CONTROL SYSTEM and P0730 GEAR RATIO...does this two codes has anything to do with my problem?
help is appricated..
Old Jun 30, 2005 | 01:35 PM
Lord Helmet's Avatar
Default Re: For the TECH here, need help badly! (Mr_Q)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Q &raquo;</TD></TR><TR><TD CLASS="quote">the gear on my 98 automatic prelude will not select itself, what i mean by it, is that when i'm on drive you know how the gear suppose to just select itself when the rpms hit certain number..well mine would just stay there and the engine just rev up, i would have to like tab the shifter up and down a lil' bit for it to switch, but sometime it switch to a lower gear instead of to the next gear..at the shop they would pull up this two codes: P070 TRANS CONTROL SYSTEM and P0730 GEAR RATIO...does this two codes has anything to do with my problem?
help is appricated..</TD></TR></TABLE>
There's the problem. The tranny control system is faulty or damaged, it's preventing the gears from automatically shifting. Also have you maintained the car yourself or take it to a shop? Replaced the tranny fluid and filter lately? What's the level on the tranny fluid level? within specs?
Old Jun 30, 2005 | 05:30 PM
slomofo's Avatar
GDD Member
Use seqential shift for now. I think your trans is going bad.
Old Jun 30, 2005 | 11:08 PM
Mr_Q's Avatar
the car is at the shop, this mechanic fix the tranny, but he now said it's an electrical problem not the tranny..he took it to a dealership and that's the two codes they pull up...but you know his job is just to fix the tranny...so now he left me with all this messed..what's this Tranny Control System about? ..and can it be the Relay outlet inside the shifter box, "console"??
Old Jul 5, 2005 | 08:00 PM
Mr_Q's Avatar
still needs help...anybody got any idea?
Old Jul 5, 2005 | 08:48 PM
slomofo's Avatar
GDD Member
There's a separate ECU that controls your transmission, maybe there's something wrong with it.
Old Jul 5, 2005 | 10:12 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (slomofo)
Go get one from a junkyard and replace.
Old Jul 6, 2005 | 09:28 AM
Mr_Q's Avatar
are you talking about the MAIN ECU under the carpet? if not than where is this ECU locate at?
Old Jul 11, 2005 | 10:25 PM
Mr_Q's Avatar
still needs help
Old Jul 12, 2005 | 04:21 AM
JimBlake's Avatar
Default Re: (Mr_Q)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Q &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about the MAIN ECU under the carpet? if not than where is this ECU locate at?</TD></TR></TABLE>
Older Hondas have separate units:
ECM = engine control module (everybody here likes to call it an ECU)
TCM = transmission control module
My '98 Accord has them combined into one unit:
PCM = powertrain control module
Maybe your Prelude has them combined also.
mony725
Aug 25, 2008 01:11 PM
kinvid22
May 22, 2007 09:21 AM
NinjaTech
Mar 10, 2005 06:04 PM
onyx00
Feb 25, 2005 11:45 AM
