which is it: clutch, master cylinder, or slave cylinder
I was driving my ls swapped hatch the other day, had it revved up to about 5.5k in first, and went to shift into second and the clutch didn't disengage.
I immedately thought the clutch was bad, but after that one incident it hasn't done it again since. There were no signs of anything wrong with my clutch up until that point, and it doesn't slip at all.
The clutch has about 80k on it.
Now, after the fact, my car drives slightly different. Pedal feel is the same, and there are no odd noises, but it sometimes shifts silky smooth, but other times doesn't want to shift, almost as if I didn't even push the clutch in and I'm trying to power shift it. I won't go into gear sometimes and will give that whinning noise.
Based on what has happened so far what would you think it is? The clutch, clutch master cylinder, or slave cylinder?
The clutch fluid is at a good level, and no visual issues.
Re: which is it: clutch, master cylinder, or slave cylinder (bambbrose)
the clutch. Im pretty sure about this isnt the same thing happened to my ex-girls GSR. I replaced the slave cylinder since it was leaking but it wasnt the problem so i dropped the trans and the a spring in the hub of the disk and broken loose and would get between the diska nd the flywheel so it would shift sometimes and then it wouldnt
s1ngle
13
09-21-2005 12:01 PM
