wiring question for vtec pressure switch
Old Jul 7, 2005 | 10:48 AM
ViXoN Hatch94's Avatar
Default wiring question for vtec pressure switch
i have a code 22 on a b16a motor with obd1 p72 ecu. this setup worked fine with a 92 b16a (vtec worked fine). used to get code 22 only in 5th gear but now the CEL just stays on. only changed longblock along with dizzy, IM and TB.
i rewired my vtec switch, solenoid, and ground. changed solenoid twice, switch twice, compression test 195 all four cylinders, had wiring checked by a CEL diagnostic tool and 3 diff mechanic shops checked wiring and told me everything is in its place and that i have a healthy motor... basically its a stupid problem i cant figure out... if anyone can think of anything plzzzzz respond!!
now to my original question... i wanna make sure my green switch wiring is right cuz my buddy messed with it tryin to be a hero... i wanna confirm the destinations of the two wires coming out of the switch, the all black wire and the blue/black stripe wire. im guessing the all black is ground but just wanna 100%. thanks
Old Jul 7, 2005 | 11:11 AM
Default Re: wiring question for vtec pressure switch (ViXoN Hatch94)
just wanna make sure but i read sumwhere that automatic motors might cause weaker vtec because of their cams... now when i was swapping the second motor, i remember the mechanic saying the plate attached to the tranny side of the motor is for an automatic tranny which led me to believe that my motor was originally in an auto car. anyone have a clue bout this one?
Old Jul 8, 2005 | 01:47 PM
Old Jul 10, 2005 | 09:11 AM
c'mon
Old Jul 10, 2005 | 09:30 AM
suspendedHatch's Avatar
That's called a flexplate, and no, that's ridiculous. Cams don't determine oil pressure, and if auto's threw codes for vtec, then all the auto EXs and JDM auto vtec motors would have been recalled. I seriously doubt that the auto has milder cams in the first place.
Where in CA are you located?
Old Jul 18, 2005 | 02:00 AM
Default Re: wiring question for vtec pressure switch (suspendedHatch)
glendale
Travis R
11
Jul 23, 2011 06:04 PM
h22a-cb7
Jun 10, 2009 05:32 PM
Nisif
Apr 21, 2009 08:48 PM
ToeJam
Apr 3, 2008 06:01 PM
Boosthead
Feb 4, 2006 07:51 PM
