Oil filter test????? which one????
Old Jul 7, 2005 | 01:52 PM
DeDonDeRosa's Avatar
Default Oil filter test????? which one????
ok i saw awhile ago that someone asked about which oil filter was the best to use
ex Fram, K&N, Mobil 1, Purolator etc..... does anyone remember the website that did the test on a whole bunch of different oil filters
i searched and cant find anything on it
so please post it and let me know
Old Jul 7, 2005 | 05:15 PM
Default Re: Oil filter test????? which one???? (DeDonDeRosa)
ttt
Old Jul 7, 2005 | 05:21 PM
TheGSRGuy's Avatar
BobIsTheOilGuy.com
Old Jul 7, 2005 | 06:14 PM
mmuller's Avatar
Mad Scientist
Default Re: Oil filter test????? which one???? (TheGSRGuy)
i use napa gold
Old Jul 7, 2005 | 08:24 PM
Default Re: Oil filter test????? which one???? (mmuller)
but i dont think that site has oil filters
Old Jul 7, 2005 | 11:44 PM
mmuller's Avatar
Mad Scientist
http://theoildrop.server101.co...m;f=6
http://www.oilfilterstudy.com/
Old Jul 8, 2005 | 12:04 AM
JDMOrangeFever's Avatar
OEM Honda is the way to go
Old Jul 8, 2005 | 01:46 PM
Default Re: Oil filter test????? which one???? (JDMOrangeFever)
IDK WHY buy every honda filter i bought when i went to change it at 3k miles it was like coming apart from the inside on my crx
Old Jul 8, 2005 | 04:30 PM
vegaskurt's Avatar
The oem s2000 filter is supposed to be really good and fits most of our motors.
Old Jul 8, 2005 | 08:36 PM
PrettyLude's Avatar
Default Re: Oil filter test????? which one???? (vegaskurt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">The oem s2000 filter is supposed to be really good and fits most of our motors.</TD></TR></TABLE>
its a good filter, due to the size and the slight increase in oil pressure
Old Jul 9, 2005 | 02:17 AM
9341civic's Avatar
Default Re: Oil filter test????? which one???? (PrettyLude)
i'm using the mugen oil filters from kingmotorsports.com
Old Jul 9, 2005 | 07:34 AM
mmuller's Avatar
Mad Scientist
Default Re: Oil filter test????? which one???? (9341civic)
not all honda filtes are good... most are made by fram= crap ;
then filtertech( wich is owned by Toyo Roki Manufacturing Co. LTD.) wich is a good thing.
A01= filtertech= good
A02= fram= crap
as for oversized filters, napa gold takes the price
Old Jul 9, 2005 | 07:43 AM
h2392si's Avatar
Fram are not crap filters. ive used them for years on all out cars and NEVER had a problem with them and all the motors run perfect. just get some castrol oil and a fram filter ad youre good to go.
Old Jul 9, 2005 | 07:50 AM
mmuller's Avatar
Mad Scientist
Default Re: Oil filter test????? which one???? (h2392si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si &raquo;</TD></TR><TR><TD CLASS="quote">Fram are not crap filters. ive used them for years on all out cars and NEVER had a problem with them and all the motors run perfect. just get some castrol oil and a fram filter ad youre good to go. </TD></TR></TABLE>
does anybody even read the links above? please read and then make new conclusions..thanks
i have had problems with fram filters..for example stuff inside comming off and handicapping oil pressure.
Old Jul 9, 2005 | 01:04 PM
Suck my DX's Avatar
i use a fram oil filter on mine...i have heard stuff about different filters being able to flow more than others..is there a chance that the fram filter flows less than others...the reason i ask this is because i have a very weird cel22 problem...if im on the freeway at around 80 in 5th and i floor it and get up to anywhere over 95 mph and then take my foot off the gas the cel comes on....i do regular maintenance on my car so i know i have the proper amount of oil in it (when the oil is low it does it more often sometimes in 3rd gear)and the solenoid filter is clean....could this be a bad oil pump?
Old Jul 10, 2005 | 09:43 AM
Default Re: Oil filter test????? which one???? (Suck my DX)
so what is the best filter out there that will give you the best flow and best filtration and have the highest oil pressure!?
Old Jul 10, 2005 | 12:34 PM
builthatch's Avatar
MiG-21 superfan
i go between 5-10k between oil changes (depends on driving situation) and i find that using the k&n offering(s), which received great reviews in the link that mmuller provided are SO easy to remove due to the nut they put on the end; makes life easier + it's a damn good filter...
sure, it's a little expensive vs. the OE filter, but it's easier to remove and has a good rep.
Old Jul 10, 2005 | 05:58 PM
MenaceL.A.671's Avatar
**** i use cheap oil filter like ac delco or napa... i change my oil every 1500 miles.. due to the fact its lsvtec.. i want my motor clean... and plus i dont drive it alot...
Jewls
24
Jan 17, 2009 05:16 PM
redline870
12
Oct 3, 2008 05:13 PM
AznMTboy
Jan 5, 2005 09:20 PM
no2unenolife
Jul 2, 2003 06:52 AM
BERT-O
Feb 14, 2002 07:06 PM
