header for b16/cams?
Old Jun 30, 2005 | 10:11 AM
haydn's Avatar
Default header for b16/cams?
What header would one recommend for a ported b16 head w/ skunk2 stage2 cams? maybe a few ideas? b20 block is in the works for later down the road, so i'd like to keep that in mind for fitment purposes.
thanks guys.
Old Jun 30, 2005 | 11:16 AM
mastarolla's Avatar
Default Re: header for b16/cams? (haydn)
Wait untill you get the longblock setup finished as optimum header efficiency is defined in part by cylinder volume...
buying a GOOD header for a 1.6 block will yield different results for a 2.0
Old Jun 30, 2005 | 03:51 PM
haydn's Avatar
Default Re: header for b16/cams? (mastarolla)
ok that makes sence thanks. Should I aim for a high comp b20vtec which header is ideal? or should a turbo come into play for low comp, what about those circumstances...?
Modified by haydn at 6:28 PM 6/30/2005
Old Jun 30, 2005 | 04:49 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haydn &raquo;</TD></TR><TR><TD CLASS="quote">ok that makes sence thanks. Should I aim for a high comp b20vtec which header is ideal? or should a turbo come into play for low comp, what about those circumstances...?</TD></TR></TABLE>
For a 2-liter VTEC setup, I'd recommend an SMSP B20/VTEC piece. In the case of a low-compression turbo setup, you'll be shopping for a turbo manifold, not a header.
Old Jun 30, 2005 | 05:33 PM
haydn's Avatar
Default Re: header for b16/cams? (Padawan)
sorry i'm new to honda, i'm completely euro. With that said may I ask what the acronym SMSP means? and as far as a manifold for a turbo setup, would it prity much just be choice of brand, at which point it just becomes ones interpretation?
Old Jun 30, 2005 | 05:48 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haydn &raquo;</TD></TR><TR><TD CLASS="quote">sorry i'm new to honda, i'm completely euro. With that said may I ask what the acronym SMSP means? and as far as a manifold for a turbo setup, would it prity much just be choice of brand, at which point it just becomes ones interpretation?</TD></TR></TABLE>
SMSP is Stadulis Motor Sports Products, a company that offers high-performance exhaust components. Here is a link to the company website: http://SMS-Products.com/
My familiarity of forced-induction components isn't terribly extensive, and I would suggest searching and posting in the F/I forum for that sort of information. I can tell you, however, that there are indeed differences in quality and performance among the various turbo manifolds, so it will behoove you to research thoroughly before you make a selection.
Old Jul 1, 2005 | 08:20 AM
haydn's Avatar
Right on man , thanks a bunch for the information. Research is something that kind of comes with the territory of a new project, and I look forward to what I may learn.
Thanks again *
sii.
Jan 18, 2014 04:28 PM
honda_ef9
Jan 23, 2007 03:27 PM
b18jdmteg
Sep 26, 2006 06:34 AM
Suck my DX
30
Sep 10, 2006 10:17 PM
PaImportTuner
Dec 29, 2004 05:36 AM
