check engine light on?....NEED HELP!!!
Old Jul 1, 2005 | 09:24 AM
turbochargeb18c's Avatar
BANNED
Default check engine light on?....NEED HELP!!!
need help...my car is throwing check engine light on
3 = map
7 = tps
1 = o2
16 = fuel injectors
41 = o2 heater
well id check for everything and could find anything...i mean,id check the map and its workin properly...when i unplug the map, the car suddently cut off,so i know that its working fine...the o2 sounds like it working because my a/f ratio gauge is reading correct...id unplug my injector plug on by on and everyone seems to be getting the right signal,im running on stock injectors....im not really worry bout the o2 because im bout to get a hondata next week....but i need to fix the map,tps,& fuel injectors...
Old Jul 1, 2005 | 12:18 PM
BANNED
Default Re: check engine light on?....NEED HELP!!! (turbochargeb18c)
anybody?????...
Old Jul 1, 2005 | 01:19 PM
theinfamouskonrad's Avatar
what obd are you running and did you convert at all? just wondering maybe you connected the wrong wires for the 4 wire o2 sensor.
pedrolucas
Dec 30, 2009 06:34 PM
91highryda
10
Nov 7, 2007 04:43 PM
racing27
Jun 28, 2006 10:57 AM
JinDIESEL
Sep 17, 2004 06:33 AM
