No pressure on clutch..??
Old Jul 8, 2005 | 01:00 AM
JFG Kevin's Avatar
Default No pressure on clutch..??
I just put in my new clutch..ACT heavy....everythin is new in there just finish my break in miles today... So i decided to go see how the clutch grabs. But that **** is feelin like ****.....the clutch pedal is super soft, and it feels like whenever i'm dumping the clutch, it doesn't feel like it. I feel like the pressure plate is VERY weak, or something. Any idea's what's wrong with it?...My clutch fluid is full, i'm thinkin it can be air in my line. What you think?
Old Jul 8, 2005 | 02:06 AM
93vtec's Avatar
Default Re: No pressure on clutch..?? (aznstyler119)
bleed it
Old Jul 8, 2005 | 03:20 AM
clutchelements.com's Avatar
>lol<
hey sups i manufacture clutch kits and by the looks of it u got robbed!
if the pedal pressure feels week then the clutch is a pice of shhhh.
ohkay what makes the clutch is the pressure plate if the pedal is hard it
holds more hp and it grips harder. but if u get a 6 puck disk with a week
pressure plate you only ganna hold maybe 10 more hp than normal
if u steel need a clutch hit me ups!
ALL Type R | B20 | B16 | B18 | B17 90 and up $395.00 " holds 400 hp "
comes with:
1. Xtream heavy duty dual diaphragm pressure plate "
1. Your choice of a 6 puck disk with or with out a solid or sprung center
" disk comes with metalic pucks "
1. Alignment tool
1. Pilot bearing
1. throw out bearing
All clutch kits are track and dyno tested for proven performance
and customer satisfaction! for pics or more info contact me at 1-323401-0383
Old Jul 8, 2005 | 10:23 PM
JFG Kevin's Avatar
Default Re: No pressure on clutch..?? (clutchelements.com)
It's an ACT clutch kit. I'm pretty sure that's not the problem.
Old Jul 9, 2005 | 05:03 AM
non-VTEC's Avatar
you need to bleed the clutch master cylinder.
Old Jul 9, 2005 | 05:51 AM
mcgee*'s Avatar
Cigarette Squad
Default Re: No pressure on clutch..?? (non-VTEC)
had same problem bleed it
Old Jul 9, 2005 | 03:42 PM
JFG Kevin's Avatar
Default Re: No pressure on clutch..?? (So_Skilled_01)
THX FOR THE REPLIES...going to do it, let you guys know what happens.
Old Jul 12, 2005 | 10:57 AM
JFG Kevin's Avatar
Well, i bleed my clutch system, and it feels better, it actually chirps at high end now. But it still doesn't feel like it's catchin hard at the low end, and the pedal, doesn't feel all that heavy either. It feels just the same as stock. Is that how heavy act presure plate suppose to feel?
Old Jul 12, 2005 | 12:13 PM
B6tPoweredMx3's Avatar
when you replaced your clutch did you have your flywheel resurfaced?
Old Jul 12, 2005 | 08:58 PM
JFG Kevin's Avatar
Default Re: No pressure on clutch..?? (B6tPoweredMx3)
it was a new flywheel.
Vinde
Transmission & Drivetrain
Oct 30, 2014 08:14 AM
crazyguy
Jun 21, 2007 08:11 AM
