weird
Old Jul 5, 2005 | 03:45 PM
blackPiE's Avatar
Default weird
I just got my first swap and it's not running well. I have jdmb18c and using a P72 ecu. Once in high rpms it revs funny. Also its throwing a check engine light.
Any help thanks guys.
Old Jul 5, 2005 | 05:54 PM
blackPiE's Avatar
Default Re: weird (blackPiE)
hey guys please help on this
Old Jul 5, 2005 | 07:37 PM
slomofo's Avatar
GDD Member
Little more info?
Old Jul 5, 2005 | 07:59 PM
blackPiE's Avatar
Default Re: (slomofo)
I DON'T KNOW IF CAUSE IM USING ITR MANIFOLD OR IF THE MAP SENSORS ARE JACK UP. BUT IT RUNS FINE AT LOW RPMS AND AROUND 6500 IT TAKES A ****.
Old Jul 6, 2005 | 04:45 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackPiE &raquo;</TD></TR><TR><TD CLASS="quote">Also its throwing a check engine light.</TD></TR></TABLE>What error code?
Old Jul 9, 2005 | 09:46 AM
blackPiE's Avatar
Default Re: weird (JimBlake)
22 code
Old Jul 9, 2005 | 12:55 PM
Suck my DX's Avatar
thats for ur vtec oil pressure switch...first thing i would say to do is to check your connection...the plug might be kinda loose on your sensor and at high rpm when there is a lot of vibration it might lose connection and cause the light to come on...when the cel22 comes on does it go away when you restart the car....and last i would take off the vtec solenoid and clean all the crap outta the filter
Old Jul 10, 2005 | 09:48 PM
blackPiE's Avatar
Default Re: weird (Suck my DX)
Thanks for lookin out yo
Old Jul 10, 2005 | 10:06 PM
blackPiE's Avatar
is something to worry about.
Old Jul 11, 2005 | 04:21 AM
JimBlake's Avatar
Is there still a question?
Code 22 is the VTEC oil pressure switch, it's forward of the distributor with a green plastic plug. It sticks out to the side of the VTEC spool valve. Check for loose/dirty/corroded connection.
But I've heard (not sure?) that JDM engines don't HAVE that pressure switch, so maybe your ECU is USDM & it's looking for a switch that isn't there?
Jamesflo
Sep 8, 2012 08:24 AM
lvlistchif
Oct 4, 2009 11:40 AM
LLK KING
18
Jul 10, 2009 09:53 AM
grlstockb18c1
Nov 3, 2004 07:07 PM
scmaguigan
May 22, 2004 05:21 AM
