Intake air temperature sensor and air filter question
Old Aug 3, 2015 | 06:54 AM
HuntsAlone's Avatar
Default Intake air temperature sensor and air filter question
So I was replacing my starter and had to take the air filter off. I forgot what connects where. Does that tube go into the air filter? Or does it go to the sensor?
Old Aug 3, 2015 | 01:54 PM
v4lu3s's Avatar
RTFM
Default Re: Intake air temperature sensor and air filter question
that is the IAT. Since you didnt htink it mattered what car or engine im going to guess you have a 96-00 civic and a b series swap as well as an intake that is NOT for a 96-00 civici. it should be in the intake tube since that is where it is designed to be. you may need to gut the proper bushing and drill your intake tube to put it in correctly, or splice a new plug and use the iat in the manifold if it is there.
Old Aug 3, 2015 | 04:23 PM
HuntsAlone's Avatar
You are correct on the engine. It's a b16a1 and it is a 99 civic si. However, since it should be pretty obvious that I am not very car savvy could you please explain the process of doing this as if I am a 5 year old.Thank you!
Old Aug 4, 2015 | 02:45 AM
HondaPartsHero's Avatar
Technical Hero
youll need to drill a hole then pick up a grommet for a pvc system at the parts store like so
Should look like this when you're done
Old Apr 5, 2023 | 07:59 AM
massimo.ek's Avatar
Do any places sell that grommet? Sorry I know this thread is old. But I have a k&n intake with a small hole for the iat and no grommet. I also have a skunk2 IM with an iat on it. Is it just easier if I cap the intake off and splice and extend my iat to the IM? Thanks
stefo
Honda Civic (2001 - 2005)
Sep 8, 2009 08:56 PM
Neptronix
Jun 25, 2007 09:39 PM
JDMCRX
May 17, 2006 03:57 PM
oOJ-GrindOo
Jul 30, 2004 08:24 AM
