electrical help needed! starting problem integra
Old Aug 5, 2015 | 08:06 PM
uniquerider's Avatar
Default electrical help needed! starting problem integra
So my 95 integra won't start sometimes. It's been a growing problem the past 3 years. It will click all the relays when I turn the key into the start position but it will not turn the starter. The starter will even click. I've put multiple starters in and it hasn't changed anything but if I turn it enough times it will start.
I pulled voltage at the starter signal and I get battery voltage when I put the ignition in the start position and the start signal not connected to the starter. But when I pull voltage when the starter signal is connected to the starter it only pulls 4 volts. I've been fighting this problem for years now and I'm clueless. I could really use some help.
Old Aug 10, 2015 | 11:14 AM
Default Re: electrical help needed! starting problem integra
Bump
Old Aug 10, 2015 | 11:49 AM
09chaplak's Avatar
Loves Tossing Salad
Are your grounds good?
Old Aug 10, 2015 | 02:53 PM
O ohms from the starter to the chassis. Also if I jump from the starter power to the signal it will turn over.
Old Aug 10, 2015 | 04:04 PM
holmesnmanny's Avatar
What do your starter contacts look like ?
Old Aug 10, 2015 | 04:12 PM
Like inside the starter?
Old Aug 10, 2015 | 04:26 PM
Yes
It's possible somehow the solenoid is bad. Doesn't happen often but it's possible.
Old Aug 10, 2015 | 04:33 PM
I can hear the solinoid click but the motor won't turn over. I've put like 5 starters in this car and it's never fixed the problem.
Old Aug 11, 2015 | 12:39 AM
It's very possible the ignition switch is bad. In fact, I would say highly likely. It may not be able to handle the voltage going passed the solder joints due to excessive resistance.
You can do a voltage drop test to confirm across the solder joints.
First, though, test for resistance from the starter casing to the negative battery terminal post. Make sure to touch the post itself.
Old Aug 11, 2015 | 12:42 AM
Here, scroll down to Checking The Starter Circuit.
Voltage Drop Testing
Old Aug 12, 2015 | 09:14 PM
Boom got it! Ended up being the ignition switch. Was putting out 2 volts less than the battery power. Thanks for your help! Looks like it is time to go push button start.
Old Aug 12, 2015 | 11:00 PM
No problem. Just get another ignition switch. They are one of the easist things to replace unless you got an alarm.
Jack Murphy
Jun 21, 2017 06:23 PM
battleREADYb20
Apr 30, 2009 02:36 AM
Touge Tuning
May 3, 2006 11:14 AM
crx1856
Aug 20, 2003 10:24 PM
elpermgrande
Aug 9, 2002 06:43 AM
