Motor shake around certain RPM range
What would cause a motor to vibrate and shake in-between a certain RPM range but then clears up when below or above that range? I have a 1992 Integra and during cold start up's the rev would vibrate and cause a shake inside the car because it's within the 'range of vibration' of the motor..... but when it warms and the idle drops, the motor becomes normal, and if you rev over that RPM vibration range, it clears up and runs smooth.
The range of vibration RPM's from that motor is somewhere between the window of 1,200-2,000 RPM's. I checked to see if it was the motor mount, but they seem to look fine. What could cause this symptom?
Re: Motor shake around certain RPM range
Do you think it's possible that the flywheel is out of balance or perhaps the crank pulley?
Anything with the rotating assembly would be most pronounced at lower rpm and smooth out at higher rpm, not occupy a specific rpm range. The B-series engines don't have balance shafts, so its entirely likely that a bad engine mount would allow a harmonic resonance at a specific rpm to propagate and create that vibration.
I had this exact problem where the engine would shake at a certain rpm and would go away as the rpm went higher but this would only happen while I was driving. It turned out to be one of my axles cause they had lost all the grease inside the boot and the joints were seized up real good. Try taking a look at them and see if that could be your problem. GL
It doesn't have to happen when driving..... it's the same when it's parked in the garage and I'm just warming up the engine. It's not the Axle/CV joint.
It seems like the motor mount could be the culprit, but we'll see. I remember owning the same type of car and had some eff'd up motor mounts, not to mention 1 missing, and the car never shook or anything like the one I have right now.
Eyal 951
12-24-2007 09:35 PM
defkid999
10-07-2007 11:49 PM
