REBUILT MOTOR/MISFIRE#2 HELP PLEASE
Old Sep 23, 2015 | 02:35 PM
jgciviceg's Avatar
Default REBUILT MOTOR/MISFIRE#2 HELP PLEASE
HI Guys,
recently I pickd up a b18c1 block, replaced bolts with arp (headstuds/rod bolts)
new water pump/oil. pump, etc... block guard
when I start the car every header gets warmed up and hot EXCEPT CYLINDER 2, FROM DIZZY SIDE WORKING TOWARDS THE RIGHT...
TOOK THE head off and had a machine shop do a leakdown test..inspected and no issues...
new headgasket and torqued back down..
THE PROBLEM STILL PERSIST AND MY B18C1 SOUNDS LIKE A SUBARU...
WHEN I START IT A PUFF OF WHITE SMOKE COMES OUT AND THEN GOES AWAY....
IVE BEEN READING IT COULD BE A BAD INJECTOR SO IAM GOING TO PLAY AROUND WITH THE INJECTORS AND CHECK COMPRESSION...
RUNNING OUT OF IDEAS, PLEASE HELP.
*BLOCK WAS HONED/NEW PISTON RINGS/BEARINGS/FULL REBUILT, LEFT THE HEAD STOCK BUT THE MACHINE SHOP CHECKEDIT AND IT LOOKS GOOD..
Old Sep 23, 2015 | 05:40 PM
Muckman's Avatar
Moderator in Chief
Default Re: REBUILT MOTOR/MISFIRE#2 HELP PLEASE
You're describing cylinder #3. #1 is always closest to the timing belt/chain.
Do a compression test. If the dead cylinder has compression that is similar to the others then Its very simple process of elimination from there. Its either a dead injector/injector wiring or bad spark plug or spark plug wire to that cylinder. You Can try swapping injectors to see if the problem follows the suspect injector.
melyk7
Apr 25, 2011 01:35 PM
shivic
Jan 8, 2009 10:26 PM
91integraLSVTEC
Dec 24, 2008 10:27 AM
EkFG
17
Jul 9, 2008 09:47 PM
str8drift
15
May 31, 2005 09:01 PM
