Lost all of my Coolant!
Old Sep 18, 2015 | 11:57 PM
CHANCELLOR12's Avatar
Default Lost all of my Coolant!
So i was driving home from work at 2 in the morning, and when i got around the corner from my house i notice the temp guage higher than normal, when i got home i popped the hood and there was coolant all near the bottom of the radiator, radiator hoses on the engine and even near the headlights.
I think my lower radiator hose came lose, will that make it spray everywhere?
In the morning i will check the hose connections and fill up the radiator to see if thats where it leaking from (the actual rad has no coolant on the fins and is not damaged).
Any tips?
Old Sep 19, 2015 | 04:16 AM
m4xwellmurd3r's Avatar
If you have a busted lower hose, bye bye coolant. All of it will drain out
Only tip is find the leak and fix it.
Old Sep 19, 2015 | 12:38 PM
Default Re: Lost all of my Coolant!
Took the rad out, filled it with water and it just started spraying near the middle of the rad, a rock hit the fan and put a hole in the rad. Gonna order a Skunk 2 Alpha, Yonoka or Mishimoto radiator.
My current fan has a small chip on the edge of 2 of the blades, should i order a new fan and shroud as well?
Old Sep 19, 2015 | 01:25 PM
Just ordered the skunk 2 alpha, will take a couple weeks to come in. Im just gonna use the stock fan.
Im so glad that i was almost home when this happened, my engine sounded fine and i dont think it overheated too much, lets hope it okay.
When I install it, I know I have to purge or bleed the system, do i just fill up the rad and start the car with the cap off and the heater on, then top it up untill it bubbles over?
Old Sep 19, 2015 | 06:30 PM
What engine is it? On b series engines, the coolant outlet on the head has a little bleed nipple you pop open as you fill to help air escape. After you fill it till coolant pours out, you close that, start it with the cap open, and top it off while running. Water temps will come up and the tstat opens and you should see more coolant flowing into the radiator. When that happens I keep topping it off till it stays nice and full to make sure all the air is out.
Old Sep 19, 2015 | 06:48 PM
Originally Posted by m4xwellmurd3r
What engine is it?
It is a B16a, i will look for the bleed nipple when i fill it, thanks.
Old Sep 20, 2015 | 01:27 PM
Do i just unbolt that whole fill nipple thing, mine looks open right now
Old Sep 20, 2015 | 02:40 PM
It works like a brake bleeder valve. You just loosen it a bit and it opens it up, no need to remove it completely.
Old Sep 24, 2015 | 10:30 AM
Well i got the new rad in and filled up, went to get gas, come home and theres oil leaking from the cam area, but the rad is perfect, the dealership said its all the cam seals and gaskets in the area, a plastic cover was grinding the seals and tore them up. On to the next repair... I dont have the skills to do it and will just end up breaking more. So im having someone replace all the gaskets, its gonna be costly.
Old Oct 8, 2015 | 03:47 PM
Just an update, got my first set of oil leaks fixed, it was the cam seals and valve cover gasket but now 2 weeks later i noticed more oil coming from the opposite side of the engine. Brought it to my local mechanic to check it out and he said it looks like the headgasket but he doesnt want to deal with it lol. I also noticed my shifter acting weird, hard to shift into 1st and it wont shift into Reverse sometime, mechanic said it could be the rod linkage. I took it to a dealer, will find out all about it tomorrow when i hear back from them
Old Oct 9, 2015 | 07:16 AM
Heard back from the dealer, it is not the head gasket, it is the distributor seal, and oil pan. And the shifting problem is a tranny leak. It is all just coming from the seals, there isnt anything broken.
What could cause all this to happen in 4 weeks, i bought the car less than a month ago. The previous owner did the engine swap himself and i think he just never sealed it up properly.
EGcivic_95
31
Jan 29, 2011 06:09 PM
K2sInteg98
Feb 21, 2008 12:19 PM
jwlee7ucla
Aug 7, 2007 03:48 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
PearlWhiteAccord
Sep 25, 2002 12:15 PM
