Alternator
Old Sep 12, 2015 | 08:41 PM
Spencerk10's Avatar
Default Alternator
Ok so I just put a new alternator in my car, new battery, and it ran for about a day and now the alternator isn't kicking in its completely shot again we took the positive connection off of the battery while it was on and it died and the alternator didn't kick in. Any ideas? Need some help pleasse
Edit Reply
Old Sep 13, 2015 | 12:22 AM
holmesnmanny's Avatar
Default Re: Alternator
Is the charging light coming on ? Year, make, and model ? What exactly is happening ? What tests have you done to determine the alternator is the problem ?
Old Sep 13, 2015 | 04:08 AM
baramund's Avatar
Edit Reply
basics: battery cable connections clean and very tight (can't wiggle), voltage regulator?
Old Sep 13, 2015 | 08:36 AM
Spencerk10's Avatar
Charging light isn't coming on, we tested the voltage with the car on and the battery in and it was at like 13 ish and then we disconnected the positive charge to the battery so the car would just be running on the alternator and it dropped to like 11.5 then the car died.
Old Sep 13, 2015 | 08:38 AM
Spencerk10's Avatar
Cable connections are clean and very tight, and idk if it's the voltage regulator that's what I'm trying to figure out
Old Sep 13, 2015 | 08:44 AM
Tachi's Avatar
Is the alternator a reman from a lower end auto parts store? They are sometimes DOA, NIB.
Old Sep 13, 2015 | 11:16 AM
Spencerk10's Avatar
I mean it's from o'reilly auto parts it's an aftermarket alternator though
Old Sep 13, 2015 | 08:48 PM
Cool the car down completely. Start the car up so it's idling at around 1500+- 200. Turn the headlights on and check how much voltage you are putting out.
Warm the car completely up. Turn the headlights on and idle the car. Idle should be 800 or so. Check for voltage. Push the gas until you get about 2000 rpms. Hold it there and have someone check for voltage.
Post your results.
89edcivic
Sep 26, 2009 02:38 PM
88 EF Hatch
Sep 17, 2009 07:29 AM
Lissav
Feb 2, 2008 03:58 PM
White Dragon
Jun 12, 2003 11:44 AM
pstutz
Apr 26, 2003 12:05 PM
