help head swap problem
Old Aug 22, 2009 | 09:07 AM
hastingsr's Avatar
Default help head swap problem
my head on my d16y8 was warped so i swaped it out for another, i got it all back together but the car wont idle and isnt running right, i have to give it gas to keep it running and its running like almost 0 vac, only thing i can think of is the timing belt is a tooth off? need help ASAP thanks!
Old Aug 22, 2009 | 11:41 AM
street_ride14's Avatar
Default Re: help head swap problem
same thing I was just thinking, you're off timing. Not sure if zero vacuum is a symptom of a timing problem but I wouldn't think so. Check timing for sure.
Old Aug 22, 2009 | 12:37 PM
hastingsr's Avatar
timing seems to be right, maby off half a tooth? but if it was off just one tooth would it make it do this, its also running super rich
hastingsr
10
Aug 23, 2009 03:03 PM
Ran4it2
Jun 4, 2009 07:39 AM
