integra wont start
Old Aug 15, 2009 | 09:01 PM
93JDMEGG's Avatar
Default integra wont start
im thinking about buying a 93 integra with a b20 swap for the engine so i can through it in my civic in the spring but i'd like to figure out what's wrong with the integra before i buy it.
when you turn the key it makes maybe one click but its not like a dead battery click and we push started it and it ran fine so im thinking its maybe starter or ignition or something like that?
just wondering if you guys have any experienced this
Old Aug 16, 2009 | 09:03 AM
Dicer911's Avatar
Default Re: integra wont start
Yea definitly sounds like its the starter gone bad on that thing. If you turn the key on and all the lights on the dash, the radio and headlamps work, but just makes a click and not turn over when trying to start, and runs when push started definitly sounds like a starter issuse otherwise the vehicle would not run as per ignition or locked up. Hope this helps a little. just curious how much are you paying for it???
Old Aug 16, 2009 | 08:15 PM
93JDMEGG's Avatar
alright yeah that makes sence. thanks
he's asking a grand.
Old Aug 17, 2009 | 06:08 AM
fcm's Avatar
fcm
Old Fart
Problem may be starter, starter solenoid, starter relay, [A/T gear position switch] ign. switch or wiring.
Try a "bypass jump", using a jumper wire, [12ga min.] connect one end to batt. pos.(+), unplug starter lead from starter solenoid and touch other end of jumper wire to starter solenoid terminal, """" MAKE SURE CAR IS NOT IN GEAR""" engine will crank even if in gear and/or ign. not turned on. 94
drkstrs24
19
Dec 24, 2023 03:51 PM
uniquerider
Aug 12, 2015 11:00 PM
3s0n3
15
Jan 3, 2013 02:14 PM
battleREADYb20
Apr 30, 2009 02:36 AM
blueb16-em1
Jun 19, 2008 05:12 PM
