Cluster = NO Lite ?
Old Aug 21, 2009 | 11:20 PM
b18c1del's Avatar
Icon2 Cluster = NO Lite ?
replaced the jdm cluster the car came with w/ a DX
cluster & plugged everything rite back BUT no lite @
cluster face & climate ctrl backlite NO lite > dials work
> how else can i troubleshoot this problem ? pls help !
Old Aug 22, 2009 | 09:49 AM
slomofo's Avatar
GDD Member
Default Re: Cluster = NO Lite ?
Have you tried turning the **** on the dimmer switch?
Old Aug 22, 2009 | 01:25 PM
jdmadam's Avatar
if its not any of your fuses and you made sure the plugs are in correctly then you probably have a bad dimmer switch. Try this, unplug your dimmer switch and take a small wire and bridge the connections, if your lights come on you have a bad dimmer switch.
ridgewayballa
Jul 2, 2008 10:55 AM
93Civic_hb
Apr 4, 2008 03:50 AM
memorybox
Sep 11, 2006 06:42 AM
Frog
Nov 8, 2002 11:51 AM
