b18a swap code6(ECT) and code14(IACV) HELP
Old Aug 5, 2009 | 07:10 PM
1xfastxhatch's Avatar
Default b18a swap code6(ECT) and code14(IACV) HELP
95 cx b18a1 swap, check build thread in sig for info on swap
still have codes 6(ECT) and 14(IACV) after checking both the sensors and wiring.
the plugs were swaped when i iniatially started the car but i have since then rewired them correctly. also the fan wont come on.
this has me stumped, according to the manual it should be fine. help is greatly appreiated
Old Aug 5, 2009 | 07:51 PM
mtber's Avatar
Default Re: b18a swap code6(ECT) and code14(IACV) HELP
Have you done continuity checks from the sensor plug(s) to the ecu ?
Have you used a helms manual to test each sensor ?
Old Aug 6, 2009 | 08:57 PM
i checked the plug voltage and sensor resistance and they both check out ok
i used the manual i got from advance auto dont remember the name
Los@ccord
May 28, 2014 06:32 AM
1xfastxhatch
Aug 6, 2009 09:03 PM
lx-sedan
Transmission & Drivetrain
Nov 17, 2008 10:55 PM
Black Si
May 4, 2004 04:57 PM
Black Si
May 4, 2004 03:44 PM
