Question about part under the hood
Old Aug 16, 2009 | 06:38 AM
sunshine36428's Avatar
New User
Icon2 Question about part under the hood
Hi,
I have a question about a part under the hood of my 2007 Honda Fit Sport. I need to know what it is and what it does. The picture below is of the part in question with an arrow pointed to it. Thanks for your help everyone!
Old Aug 16, 2009 | 06:45 AM
orioncivic's Avatar
Default Re: Question about part under the hood
i may be wrong but it looks like a type of egr. it recirculates exhaust gases back into the cylinder to make up some of the mass air in cylinder. if you can post a pic with a little more detail on where it is and what is around it i can be sure. ive not seen the inside of a fit hood before so ill need to look around to familiarize myself
Old Aug 16, 2009 | 07:42 AM
Anon51's Avatar
yup that would the the Electronic EGR.
Old Aug 16, 2009 | 08:37 AM
New User
Thanks for your help!
Has anyone ever replaced this part? How easy is it to replace?
Old Aug 16, 2009 | 11:59 AM
street_ride14's Avatar
very simple to replace, usually held on by two bolts. There should be a gasket underneath it, replace this when you replace EGR valve.
Old Aug 16, 2009 | 06:26 PM
jlude90's Avatar
Why does it need replacing? Is it not under warranty? Are you sure that valve is the problem?
Old Aug 20, 2009 | 09:19 AM
wwbubbajoe's Avatar
this would take you about ten minutes to change but if there is a warranty, take it in so you dont void it.
Old Aug 20, 2009 | 11:41 AM
Scott_Tucker's Avatar
Your warranty would not be void if you did the work yourself. Why do you think it is bad? If you don't even know what it is how could you have possibly diagnosed it correctly?
Old Aug 20, 2009 | 02:45 PM
wwbubbajoe's Avatar
no the warranty would not be viod if they worked on it but if they dont know what it is then i am assuming they dont know this vehicle well and they might accidently make a mistake that would void it
wanted-4-living
Sep 26, 2009 11:40 AM
odishaw
Aug 3, 2008 01:52 PM
ericjackson
Feb 18, 2005 09:10 AM
VTECAcuraGSR
Sep 26, 2004 08:00 PM
