help with CELL code 7
Old Aug 15, 2009 | 03:01 PM
xander1100's Avatar
Default help with CELL code 7
so my car (95 teggy with 96 gsr motor) is throwing CEL code 7, which is TPS. i checked the voltage on the middle wire its right where it should be (around .45V). anything else i can try doing or am i stuck getting a new TPS at this point?
Old Aug 15, 2009 | 06:27 PM
KWayRacing's Avatar
Default Re: help with CELL code 7
I am assuming you have check the connection and visually inspected the tps and conncetor. Will the TPS move at all I have seen JDM motors with the screws back out.and allow the TPS to move with throttle opening. You most likely have a poor connection problem. If not, wIth the KOEO you stated you measured .45 volt throttle closed. What was the value at WOT? You can sweep the throttle gradually and your voltage reading should sweep accordingly....smoothly. Does it? Measure voltage between YEL/WHT (+) terminal and GRN/WHT(–) terminal. Is there approx. 5 V?
Old Aug 15, 2009 | 11:40 PM
xander1100's Avatar
i'll have to check that tomrrow. i just checekd the throttles closed. TPS is on there steady, bolted down tight.
Old Aug 16, 2009 | 08:28 PM
xander1100's Avatar
checekd out my TPS today, voltage swept accordingly up to about 5V at WOT. which wires on the ECU harness do i check to see if the voltage is the same there? (measured it at the TPS)
or is it the sme colors? the wires on my TPS were actually green/blk and solid yellow...but then again they were dirty so it might have just been that.
Old Aug 17, 2009 | 12:10 AM
xander1100's Avatar
just a side note i have my ecu set up for solenoid boost controll but havent installed the solenoid yet. its different wires though so as far as i know that wouldnt be an issue...someone correct me if im wrong
brandynEG
Engine Management and Tuning
13
Sep 27, 2013 04:51 AM
Pinarr
May 18, 2012 08:36 AM
Devious951
Sep 18, 2009 05:11 PM
gsrlkn412s
May 26, 2007 06:02 PM
ludacole
Aug 13, 2005 11:59 PM
