HELP solid cell
Old Aug 10, 2009 | 03:50 PM
jspeccrx91's Avatar
Icon2 HELP solid cell
just finished up my wire tuck and went to fire up my crx and i blew the 60 amp fuse in the engine bay fuse box. i had the alt wire and the starter wire mixed up. swapped them and replaced fuse and now i keep blowing the 10amp alt fuse under the steering wheel and the ecu has a solid cell. car wont turn over, can't hear the fuel pump, nothing. 91 crx b16 obd-0 pr3 ecu. what are my options here?
Old Aug 11, 2009 | 03:41 PM
reyracerx's Avatar
Default Re: HELP solid cell
ecu is burnt. you will need another cus the one you have is dead.
Old Aug 11, 2009 | 05:40 PM
poppypizza's Avatar
solid is ecu based,, open the ecu up look for burns,, it will also be solid cell due to power not getting to ecu. I just recently saw a car solid cell and a wire burnt up around his ignition one wire is all that it was ecu didnt burn.
Old Aug 11, 2009 | 05:49 PM
jspeccrx91's Avatar
thanks, i opened the ecu and it looks fine nothing out of the ordinary and no burnt smell. i'll have to locate the ecu power wire and go from there.
94SuperLudeSI
Apr 20, 2008 06:10 AM
shadow29485
Jun 18, 2007 04:30 PM
zacatkings
11
Mar 15, 2006 08:31 AM
XplodeTeg
Apr 2, 2005 09:07 PM
JDM CRX
Oct 3, 2002 10:35 AM
