timing offset in Skunk2 cam gear
Old Aug 17, 2009 | 02:06 PM
adbodykits's Avatar
Default timing offset in Skunk2 cam gear
Hi mates, I have a skunk2 pro camgear in my D16Y8 civic, but I find some issues that are getting me crazy.
The first one: why my cam gear shows that advance is turning the gear counter-clockwise and retard turning it in clockwise, but other cam gears show the opposite:
mine:
others:
http://bisimoto.net/store/images/bisi_cams.jpg
http://d5otzd52uv6zz.cloudfront.net/...f5a717-350.jpg
http://www.mindspring.com/~tlj/civic...gear_small.jpg
What is the right direction to advance?
Another question: as you can see in my Sk2 installation, the difference between the Z6 setting and the Y8 one (down in the cam gear) is about 2 degrees, and its all know, that the real difference between the Z6 and Y8 is about 4.75 degrees, so: should I set the cam gear to the Y8 mark, or advance it by myself the 4.75 degrees needed?
Thanks.
Old Aug 17, 2009 | 05:21 PM
philafelman's Avatar
Default Re: timing offset in Skunk2 cam gear
the bisi one looks correct to me, i believe you rotate the cam counter clockwise to advance cam timing.
austen95
Mar 12, 2018 06:55 PM
user 98292739
Mar 4, 2008 03:10 PM
portenio78
Apr 23, 2006 06:26 PM
90LSpimpin
Jan 31, 2005 01:34 PM
axhandler
Sep 11, 2003 04:48 AM
